120mm spaced 8 spee...
[Closed] 120mm spaced 8 speed internal gear hub?
3 Users
 cp
Bit of a random ponder for my singlecross, which has 120mm spaced rear dropouts.
Does anyone know if there are spacers/washers which can be removed from the axle of a Nexus/Alfine hub to make it squeeze into a 120mm dropout? Even if it just takes a few mm off the width it might help...
Alternatively, any 120mm spaced 8 speed internal hubs which any one is aware of?
Posted : 06/07/2010 12:54 pm
Thought about this myself for the same project. couldn't find anything except SA 3speed. Well without spending big money. You could do what I did and build a freewheel hub. 120mm was old 5 speed anyway and you can get 6 speed block on. you can get a mech hanger to fit on the axle. Biggest hassle is clip on cable stops and they aren't hard to find.
Posted : 06/07/2010 3:29 pm
 cp
cheers for the reply - what do you use for shifting? Are 6 speed sti's available?
Posted : 06/07/2010 3:33 pm
you can get a 5 speed - Sachs P5 Spectro in 120OLN
you coudl also have a go at fitting a 3 speed brompton hub with their 2 speed overdrive system - that is 120 oln
Posted : 06/07/2010 4:19 pm
