11 speed Shimano ch...
[Closed] 11 speed Shimano chain reusable link
Apologies if this has been asked before.
Have a Shimano 11 speed chain, don't want to join with the Shimano one time use connecting pin.
Can I use a sram or kick 11 speed link instead?
Need to get the chain off for proper cleaning and lubing.
Posted : 06/03/2017 8:33 pm
Yes, although both the Sram and KMC 11spd links are designed to be single use only.
Posted : 06/03/2017 8:34 pm
Thanks, but been re using all manufacturers links for ages without any issues.
Posted : 06/03/2017 8:38 pm
I'm using the YBN 11 speed from Merlin with no problems.
Posted : 06/03/2017 10:47 pm
I've had a 10 speed kmc quick link on mine for the last year.. Seems fine
Posted : 07/03/2017 8:29 am
Cheers all
Posted : 07/03/2017 8:39 am
I believe the single use marking is misleading and actually means use for this chain only so you're not meant to re-use the quick link on another chain. I might be wrong.
I've detached my quick/power links (SRAM 11 speed chains on Shimano 10/11s drive trains) for crank / bb / rear mech maintenance and re-attached them many a time with no issues. Using some Park link pliers.
I carry a spare quick link with me in my pack just in case and my multi-tool has a chain splitter. Never needed to use one when out though - touch wood. The day I don't take one... ๐Ÿ˜‰
Posted : 07/03/2017 10:05 am
Same. I always remove chains (9, 10 AND 11 speeds) when bike cleaning, and swap old split links to new chains (so I have 'free' spare links). No issues. Use the BBB pliers
Posted : 07/03/2017 10:14 am
as above, they can be reused despite not being 'recommended'. Or next time you pass a Decathlon, they do own brand ones (made by KMC by all accounts) so you can have spares.
In a pinch you can use a lower speed link on a higher speed chain - eg a 10spd or 9spd on an 11, a 9spd on a 10, etc. For that reason i also carry a couple of spare 9's in my pack, left over from when 9 speed was state of the art, and where they'll fit pretty much any chain anyone will be riding they've saved rides for me and others over the years. They are a bit wider and might 'tick' a bit over the cassette but compared to walking.....
And also worth stashing a spare one to fit your bike somewhere - on my road bikes they're in coin bags and then shoved up the inside of my seatposts, have heard of others doing the same inside the hollow axle of a HT2 crank.... then you're never without.
