Which Powerlink pli...
[Closed] Which Powerlink pliers?
[#8386874]
Looking on CRC there's at least 3 to choose from.
A Park at £10.99
A BBB one at £8.49
An X Tools version at £4.99
There may be more but I haven't looked.
I failed miserably at splitting my chain yesterday but It's only about the 3rd time in 2 years I've needed to.
I like functionality & VFM but has anyone used them all & which one do you like best?
Ta!
Posted : 06/03/2017 8:11 pm
Only used the BBB ones but perfectly functional.
Posted : 06/03/2017 8:17 pm
These are the only type I have used they work great
[url= https://www.bike-discount.de/en/buy/superb-classic-2-in-1-chain-master-link-pliers-211463?currency=3&delivery_country=190 ]link pliers[/url]
The "three legged type" maybe not these exact ones
Posted : 06/03/2017 8:23 pm
jobsworth pair from planet x work perfectly too!
Posted : 06/03/2017 8:37 pm
Got some from Evans (couldn't be bothered to wait for the post) they were cheap and work fine.
Posted : 06/03/2017 9:00 pm
Really like the look of those 3 legged type. There have been occasions where they would have been very useful.
Posted : 06/03/2017 9:13 pm
 jruk
Does using 'proper' pliers mean it's easier to reuse links that aren't supposed to be reused?
Posted : 06/03/2017 9:14 pm
Yes.
Posted : 06/03/2017 9:42 pm
It's the Park ones for me but I'm sure they are all the same.
Posted : 06/03/2017 10:01 pm
BBB ones here, work perfect on 11 speed links. Make sure you get ones that open AND close. Some only do either
Posted : 06/03/2017 10:38 pm
Just filed some old pliars into the right shape.
Posted : 06/03/2017 10:53 pm
ones that close?
Just fit it and pull the chain to close it. If you don't want to dirty your hands and don't have disposable gloves in your pack, fit it, spin it gently to the top run, put the brake on and use the pedal to pull it shut.
Posted : 06/03/2017 11:03 pm
I just use normal pliers
Posted : 06/03/2017 11:04 pm
Me too.
Posted : 06/03/2017 11:23 pm
ones that close?
I'm not going to take my link pliers on a ride. In the workshop it's much nicer to be able to close the link with the pliers in the stand and then run the gearing through a test without messing around pulling a chain or using the cranks to do it. The Park and BBB ones do both in the same tool so it's not like it costs you anything.
Posted : 07/03/2017 8:55 am
im with Andy, Using the proper tool is quicker and less likely to damage the link if its off a bit. No point buying a one way tool when there are so many 2 way options. Personally I have the Topeak one and I like it, but its at the top end of the quoted prices.
Posted : 07/03/2017 9:07 am
I'm sure it is easier using some pliers to close the chain but it's not the end of the world to close it like theotherjonv said.
Posted : 07/03/2017 9:18 am
I've never had a problem closing a link, It's getting them apart that's often a problem. Like a CV joint on a car, It's either 1st tweek or takes ages.
I'm gonna go for the BBB ones cos they do both anyway.
http://www.chainreactioncycles.com/bbb-open-link-closing-link-tool-btl77/rp-prod47439
Posted : 07/03/2017 9:32 am
I bought the Park ones and am very happy
Posted : 07/03/2017 9:36 am
+1 for BBB.
Posted : 07/03/2017 9:41 am
I made one of these - works a treat
Posted : 07/03/2017 9:51 am
Posted : 07/03/2017 10:06 am
For the cost, weight and ride saving potential I now have a £5 pair sat somewhere in my Camelbak, as well as a pair at home.
I wasn't criticising the 3-legged types, just didn't even know they existed when closing a link was so simple without. I certainly wouldn't pay extra for that function, and i won't be replacing my old skool ones now i do know.
Posted : 07/03/2017 10:08 am
BBB does both, and is nice and compact. And cheap.
Posted : 07/03/2017 10:14 am
I've got the Park ones - they do a fine job (I only bought them as I had a Wiggle voucher to use up)
However prior to buying them I used to use a pair of pound shop circlip pliers with slightly bent ends which also worked perfectly.
Posted : 07/03/2017 10:22 am
