at present my 10speed chain has a powerLOCK I like to carry a spare link - can I buy a powerLINK instead? will it all still work ok?
doesn't have to be poerLOCK does it?
the links are great for cleaning too
Get a KMC one
KMC Ones - form Ebay, where they're affordably prices.
I too use the KMC ones
Decathalon, made KMC, 2 for £4
Powerlink works well on 10 speed, never had a problem
OK so if my chain snaps I join it back with a powerlink instead and all is good?
10sp Connex Wippermann - have used them for the last 8 years on Shimano + Campag chains with no problems.
[url= http://www.wiggle.co.uk/wippermann-connex-chain-link-10-speed/ ]http://www.wiggle.co.uk/wippermann-connex-chain-link-10-speed/[/url]
You will still need to carry a chain tool if you snap your chain.
Yep, all fine
I have a KMC one on my chain and a Clarke one as a spare. Both reusable types.
I dunno, shimano/SRAM chains are subtly different now*, I've no idea which way KMC aligned theirs, presumably for the roadie market, but I've no idea which of SRAM/shimano transfered the dimensions from road cassettes/chains to MTB.
Does anyone else still do it the old fassioned way, press the pin through the inner link, then push it back again to re-fit it? Supposedly weaker, but since going 1x10 I rarely have to multiple shift in a hurry so the chain's not bent as much.
On the other hand plenty of people seem to get allong fine with a 9speed link.
*one kept the sprocket thickness from 9speed cassetts and made the chain plates narrower, but the inner width is the same, the other kept the chain plates the same width and narrowed the sprockets so you theoreticaly have to match "chains and cassetts", and "mechs and shifters", but the mechs/shifters dont need to match the chain/cassette.
In my experience, yes.sefton - Member
I use the KMC ones on SRAM and Shimano chains. Work well but a right b**ch to undo (I can only do it with pliers).
Try the Wipperman links always easy to undo - never had problems with them on Shimano (including the new 10sp MTB chains) + Campag chains. You do have to put them on the right way up though.
Might ty harder on mine then, I just assumed I'd bought locking ones by accident rather than re-usable ones!
I used a 9sp Sram Powerlink on a 10sp KMC chain when it snapped during a ride and it appears to work absolutely fine.
That said the Wipperman link is the easiest to undo
File the 10spd quick link lightly with a small file and should be able to open by hand like a 9 or 8spd one.
DeeW - MemberI use the KMC ones on SRAM and Shimano chains. Work well but a right b**ch to undo (I can only do it with pliers).
This. I took a set of light weight long nose pliers to the grinder and formed a rounded rebate to suit the barrel of the chain.
Kink the chain and squeeze. Simples.
I bought these pliers http://superstar.tibolts.co.uk/product_info.php?cPath=36&products_id=506 and it makes it so easy to open and close 10 speed links, also using the KMC links from Decathlon and they work fine with Shimano and SRAM chains.
Power locks ain't locks you can re-use them.
