I have the DT Swiss RWS thru axles and they're great, but not secure and If possible I'd like to avoid the hassle of locking up my front wheel to the rest of my bike. Are there any quality anti-theft 100x9 mm thru axles out there?
on the older ones at least you could take the handles off. dunno if true of the later ones.
They have them for 12 mm axles but haven't seen any for 9 mm!
My Roadrat (circa 2012) came with an Allen key 100x9 front axel. Looks just like a normal qr, just without the qr bit. Not super secure as you only need an Allen key- but better than nothing.
Unfortunately I don't know who makes them.. possibly Alex as that was the only brand name on the wheels so I assume the hubs were also theirs
Found one from Hadley https://www.balleracing.com/hadley-front-hub-thru-bolts/hadley-thru-bolt-9mm-x-100mm which you could add hexlocks to for a secure system. You only need to unscrew one side so almost as practical as the DT swiss system. Only problem is you can only get it from the us.. $$$
Pitlock (Germany) do [url= https://www.pitlock.de/en/shop/pitlock-thru-axle-fuses.html ]through-axles[/url] as well.
l.e. sadly, not 9mm; I think your best bet would be to use a [url= https://www.sjscycles.co.uk/hub-spares/wheels-manufacturing-cromoly-9-x-1-shimano-thread-front-axle-solid-nutted-155mm/ ]solid axle[/url] from a cup and cone system and two 9mm [url= https://www.pitlock.de/en/shop/solid-axles-protection/shimano-nabendynamo-vorderrad-m9/set-sh90-single.html ]anti-theft nuts[/url].
Interesting! What does the axle look like without the handle?
