Hello,
Will the above work. E.g. An xx1 chain set with a SRAM 10 speed chain.... And not be too loose and fall off?
Thanks,
P
Posted : 10/09/2013 8:49 pm
Yes.
Posted : 10/09/2013 8:55 pm
Do you mean running an XX1 chainring/crank with a 10 speed cassette & mech?
XX1 chainring runs fine with a 10 speed set up. Friend of mine does exactly this.
If you're looking to do this, cheaper option is a thick/thin chainring from Works Components / Wolf Tooth / Raceface / and loads of others. They all do the same job. They work best with a 10 speed chain (even on a 9 speed set up).
Posted : 10/09/2013 9:02 pm
Sorry, but It will fail & u will surely die.
R.I.P.
Posted : 10/09/2013 9:10 pm
Yes, I was thinking of buying a xx1crank set. I need a new crank and chain ring so was going to buy both as it works out fairly cheap.
Thanks,
P
Posted : 10/09/2013 9:13 pm
