[Closed] brakes
[#5504836]
Formula RX Any opinions before I part with money? thanks
Posted : 10/09/2013 8:49 pm
Brilliant. Just got some a couple of months ago or so, got a fair few rides on them and they're great. Apparently because the holes in the discs are alined concentrically you can get uneven disc and pad wear - i'm seeing how I get on and might replace the discs with something else if its an issue.
I like the levers themselves cause the cylinder is out of the way at 90 degrees to the handlebars and doesn't compromise where you can fit your shifters like brakes with cylinders that run parallel to the handlebars can do. I also like the angle of the lever relative to its pivot point - it feels very ergonomic. A mate of mine has been running some for years with no bleeding or maintenance whatsoever apart from pad changes and they're still going strong.
Posted : 10/09/2013 9:38 pm
