Trying to do a 1 x 10 conversion for my brother, Shimano medium cage XT clutch mech with a E thirteen 42t 1up cassette ring.
Said XT clutch mech catches the 42t cog with it's big fat silver arm in the lowest 3 gears. Could throw the bike across the kitchen.....
Have adjusted the b screw all the way in to obtain as much clearance as I can but still no luck. Calling all drivetrain ninjas to the forum.
All the best,
Lee.
[URL= http://i777.photobucket.com/albums/yy58/generallevi/75E4139E-64C1-4A88-88B6-EC20D3720CD8_zpsabj6uho4.jp g" target="_blank">
http://i777.photobucket.com/albums/yy58/generallevi/75E4139E-64C1-4A88-88B6-EC20D3720CD8_zpsabj6uho4.jp g"/> [/IMG][/URL]
Rad cage needed I reckon
Had a similar issue with a 40t ring when in 36t and rad cage sorted it perfectly
With a 42t you need a rad cage.
If the B screw is all the way out, you need a longer B screw.
Take out the b screw, remove the plastic black thing it screwed into and you will get that bit more adjustment. I've done it on two conversions now.
Can you put the B screw in from the other side?
RAD cage sorts it.
Take off the expander thing and let him get on with riding it ๐
Are the mech and mech hanger new/perfectly straight?
This ^ I have also done it on 2 bikes, I put a rad cage on one afterwards just to try out, yes it helps but it isn't necessary or a massive difference.
Edit: Also the e thirteen ones are pants, if you find it skips send it back 'cos it'll only get worse with time. I sent mine back for a full refund despite it being used, the seller didn't put up much opposition which shows that they know they are a poor design
