1 x 10 using SLX/De...
[Closed] 1 x 10 using SLX/Deore double crankset
8 Users
Bought a couple narrow/wide chainset as Superstar were kind enough to sell them for silly money yesterday.
Both my bikes currently use double chainsets, an SLX M675 & Deore M615, however I've seen various runmblings that 2 x 10 chainsets don't provide an ideal chainline.
Does anyone have any experience of trying to set up for 1 x 10 using any of the above chainsets and how did it turn out in the end?
If it makes any difference the cassette on both is an XT 11/36 and I'll be adding an e-thirteen 42t expander to save me poor wee legs, also one is FS and the other HT.
Posted : 08/12/2014 4:38 pm
Just make sure you put the ring on the inside of the tabs and not the outside and you'll be fine chainline wise
Posted : 08/12/2014 5:05 pm
Chainsets for a double setup don't allow the ring on the outside anyway!
The outer ring on a double is around 2.5mm further out than the middle on a triple, so you have options to get the ideal spacing. Run spacers under the chainring to bring it inboard, or drop a BB spacer out and put it on the other side, moving the whole chainset over to the left. Check arm/stay/heel clearance but should be fine and you won't notice.
I had 0.8mm BB spacers and some 1.5mm chainring spacers, so did both to move the ring about 2.3mm and the chainline is great.
Posted : 08/12/2014 5:32 pm
Got an slx double here running as a 1x10.
Works very well.
Posted : 08/12/2014 5:49 pm
When running a work components 32t with a SLX double, the chain ran over the bolt tabs as the were quite high and rounded. You may need to run some spacers to stop the rub.
Posted : 08/12/2014 7:01 pm
Edit: was writing loads but i'll just share the link about this topic instead.
http://singletrackworld.com/forum/topic/show-me-you-new-style-slx-cranks-preferably-1x-setup/page/2
Posted : 08/12/2014 8:29 pm
Well this all sounds very promising.
One last question, do I need to get shorter chainring bolts or can I re-use the ones already in place?
Going to order some spacers with the 42t extender just in case.
Posted : 08/12/2014 8:30 pm
I changed from 2x10 SLX to 1x10 SLX crank arm with a 34t hope retainer.
no problem!
Posted : 08/12/2014 8:38 pm
Fitted and fine to a SRAM 2x crank, moved 1 BB spacer to compensate.
Posted : 08/12/2014 9:08 pm
