I got hold of a 2012 Revelation RLT damper for my old Pike 409 coil. It's quite a bit shorter than the old red MoCo, does anyone know how much shock oil I should put in? It fits and works, but guessing /getting the volume wrong is tiresome!
Any help appreciated!
Posted : 26/05/2018 10:11 am
I believe that the bottom of the damper should just touch the oil once fitted (+/- a few mm). This kinda makes sense in what it needs to do.
Posted : 26/05/2018 10:35 am
Cheers for the suggestion, however the level is already higher than that and the lockout doesn't work fully, so I presume the amount of air above the bottom of the damper has some bearing on compression too
Posted : 26/05/2018 1:13 pm
