Just a little update to say that I took the plunge on a Yeti ARC Carbon. All I can say is goodness gracious me it is fast. I’ve not built it up stupidly light or expensively (Fox forks, 1×10 XT, Hope Crest wheels, Renthal fatbar lite bars, Thomson stem and seatpost etc), but it ended up weighing 23.5 lbs and it is lovely. It is really well balanced front to back so jumps off any little mound really nicely. It flies uphill, on the flat and downhill as well. (Ridden at home on the Chilterns and also a ride on Exmoor so far). It just motors along with very little effort. It is direct but not in a bad stiff way. Really seems to go where it is pointed with tapered steerer and bolt through forks and then the rear just follows nicely.
I don’t think it has taken much re-adjustment coming from an On One original geared Tinbred to be honest, yes it is clearly different, but it does not feel like I’m having to learn how to ride it or anything. Still getting used to tubeless wheels and it does need less air in the tyres than I’m used to and it is noticeably more stiff if the pressure is a bit high. Think I’ve them down to about 30psi now.
Not sure it is the greatest early mini review going, but I am very pleased with it, and it looks gorgeous too 🙂
