XT Dynasys compatib...
[Closed] XT Dynasys compatibility with XTR double?
 Leon
[#2543683]
Anyone know if it's possible to put an XTR 10spd double chainset with an otherwise XT Dynasys setup?
Or alternatively, will the SRAM doubles work with the XT?
Previously, I didn't pay too much heed to these differences (I have a 7spd 105 rear mech running just fine on a 9spd road bike!), but from what I've read Dynasys is an altogether more sensitive beast.
Posted : 08/03/2011 6:27 pm
That'll be fine, though I'd get a double specific XTR front mech.
Posted : 08/03/2011 6:31 pm
 Leon
thanks.
Do you mean either XTR or a SRAM double, or just the XTR?
Probably should have checked if the shifters will be ok too? Don't see why not. Most of the road STI's used to be double or triple.
Posted : 08/03/2011 11:08 pm
I have been wondering this too.
Also -
What about if you go with an XT (3x10) chainset but just run 2 rings? Will that work with XTR Race shifters & an XT f mech, or do you need an XTR f mech?
Also with all the new rear mechs, does XT operate the same "direction" as XTR now i.e. if you go with an XT r mech on XTR Race shifters, does it work?
Dom
Posted : 09/03/2011 5:36 am
I have a Cube Stereo Race with 3 x 10, XT shifters, front Mech and XTR rear Mech, took big ring off for a bash and still works fine indeed.
Posted : 09/03/2011 1:29 pm
I don't know about this fo sho, but when setting up my XTR double chainset the shifting wasn't very good when the shifter was on the '3x' setting, ie how you'd normally run a double if converting.
I don't know if there's a different cable pull ratio or something daft for the double (newer road front mechs are different, so it wouldn't surprise me).
Posted : 09/03/2011 2:38 pm
OK, so the way I read this is you can run:
XTR shifters in 3x mode
XT f mech
XT chainset with one ring removed
XTR r mech
Then when I find some more cash I can go the XTR chainset and f mech and go to the 2x mode on the shifters
Thanks guys
Dom
Posted : 09/03/2011 9:01 pm
My experience suggests you may need the XTR double front mech if you change, although I suspect using a normal front mech you could just still use the 3x position.
I'd just stick with the converted chainset though, wouldn't bother with the xtr double, spend that money elsewhere on the bike.
Posted : 09/03/2011 9:35 pm
[quote='geordiemick00']I have a Cube Stereo Race with 3 x 10, XT shifters, front Mech and XTR rear Mech, took big ring off for a bash and still works fine indeed.
Er hello!!!
Just restrict the 'hi' screw on the front mech, no need to buy double mech or shifters then, works a treat
Posted : 09/03/2011 11:47 pm
I just realised that using XT Dynasys as a cheap 2x10 chainset doesn't work so well as the rings are a little close (42-32)...
So, can you run an XX chainset on XTR 2x10 or XT Dynasys shifters and front mech?
Good to hear of any experiences out there
Thanks
Dom
Posted : 22/03/2011 12:29 pm
You can change the rings to whatever you want, TA Chinooks are excellent. Cheaper than buying a 'proper' double, and you can have ratios you want. IMO the XTR ones are too close together.
Posted : 22/03/2011 12:32 pm
 tang
def choose your own rings up front. tune it to your riding. as nice as the xtr looks do as njee says!
Posted : 22/03/2011 12:36 pm
