XT 775 Hub bearing ...
[Closed] XT 775 Hub bearing tighten
[#3624131]
I have picked up a centrelock xt775 hub on mavic xm317 rim and there is play in the hub- how do I tighten that up- doesnt seem to be a tarditional cup n cone set up???
Posted : 30/01/2012 5:09 pm
 cp
they are cup and cone. If you take the qr skewer out, you'll see some allen key fittings in the end.
There's a tech doc somewhere on one of shimanos websites showing an exploded view of it. If you're familiar with normal Shimano hubs, it's pretty self explanatory once you've seen it.
Posted : 30/01/2012 5:14 pm
IIRC one end needs a hex key & the other is normal cone spanners, tightening is as for normal cup & cone
[edit] as cp says! [/edit]
Posted : 30/01/2012 5:15 pm
