Anyone out there running X Fusion Sweeps having trouble spacing your calliper out to fit the disk?
Got 203mm disk, and a 203mm Shimano spacer. With that fitted the calliper doesn’t quite reach far enough into the disk (it’s too far out) to the point that only the bottom third of the pads are wearing.
Figured that the forks might therefore be built for 180 and a standard 203 adaptor is placing the disk too far out, so tried a 160-180 adaptor but that doesn’t space the calliper out quite far enough and the disk rubs.
I’d this a known issue with Sweeps?
Do I just space the 160-180 adaptor out with washers and longer bolts?
Do I buy a non-Shimano 200mm rotor?
Have I missed something obvious?
