Why is 1x9 so good?
[Closed] Why is 1x9 so good?
[#3801433]
I don't really get the whole idea of 1x9. There seems to be quite a few folk running this way on here.
Is it weight saving exercise?
Is it a "theres less to go wrong" thing.
Is it fashion?
What's wrong with 27 gears or even the new 30 speed that Shimano and SRAM have been developing for years.
Surely it's a backward step?
If you want any of the above suggestions I made, why not go single speed?
I'm baffled by this trend.
Posted : 23/03/2012 9:26 am
It's just the latest STW bandwagon, and probably OK if you only ride Trail Centers 🙄
Posted : 23/03/2012 9:31 am
I see it as less weight and practical* gear range with no overlap.
* one size does not fit all however!
Posted : 23/03/2012 9:32 am
Front mechs are a joke. That's the overwhelming reason for me.
I don't need the easy gears a granny ring supplies, i dont care about spinning out on a road/fire road descent (it is MTBing).
Though i do need some gears to make the bike comfortable usable off road for myself.
Shorter mech, better chain security, less chain, less weight, less noise, greater reliability, more ground clearance. Looks better too. It also makes you a "stronger" rider too. I'm not any slower, most probably faster up the hill than anyone i ride with with a triple. When i have a go on a granny ring now, it's not any easier, just takes longer.
Different stroke for different folks though. I'm not going to worry whether people are using a double/triple/single.
Posted : 23/03/2012 9:33 am
I've been running 1x9 on my DH bike for years, never really considered sticking a triple on it. Is that what baffles you?
Posted : 23/03/2012 9:36 am
On my AM and XC bike I noticed that I just never shifted up front. I just left it in the middle ring and with 9/10 outback I just didnt feel like I needed more range. Its down to where your ride and how you ride.
Posted : 23/03/2012 9:40 am
1) simplicity of use
2) less weight by quite a bit
3) ability to run a proper chain devise
4) neat cockpit
5) aesthetics
If it's a fashion thing then I'm one of the ones who started it 😀
I've been running 1x9 and now 1x10 for about four years. My reasons for going down this route initially were simplicity and weight. Going 1x9/10 saves about 300-400g depending on what kind of chain device you then fit (and you will need one unless you're riding very gently).
The overwhelming benefit in my view is that you're always in the right ring up front and given that shifting big rings is a real faff and works less than perfectly right when you need it to work really well, there's a big benefit to be had for the ease and simplification of set up (think about why people like to ride single speeds and you're on the right lines).
All of this would only be valid if actually you didn't need your other two rings.
The big ring is a waste of space; you only ever need that if you're riding on the road, which I never do. A 32t to 36t middle ring is more than big enough for all off road riding (personally I don't see the need for anything bigger than a 32t and I've yet to be under geared going down hill).
The granny ring can be missed, but even a 100kg heffer like me still managed to ride around the Alps with nothing but a 32t by 36t low gear.
Posted : 23/03/2012 9:48 am
Its not really that different to 2x9 or 3x9 I like riding rough stuff and I was always dropping the chain. I rarely used the big or little chain ring so it seemed like a logical step. It is a pain on big climbs as I am not really fit enough to ride up everything, I will probably be pushing up parts of Llandegla and CyB this weekend but it offers me the security of knowing what my chain will be doing when I come clattering out of a rock garden.
FWIW I run 2x9 on my HT as I use that for more trail sort of stuff. I would be using it for Llandegla but we are riding Snowdon on Sunday and thats what big bikes are made for.
EDIT:
[willywaving]I used to run a DMR single ring guide on my GT Timberline and later Revel 4X back in the 90s[/willywaving]
Posted : 23/03/2012 9:50 am
1x9 is alright, I liked it, I also like singlespeed and having a triple.
Oh and I had a bike with a double for a while, I quite liked that too.
Does this help?
Posted : 23/03/2012 9:58 am
I think you're willy is bigger than mine 😀
Posted : 23/03/2012 10:08 am
because I can and I want to
Posted : 23/03/2012 10:11 am
Don't use the granny or outer cog, so why keep them on?
If it's too hard to pedal with 1x9, then I'll push - and not afraid to admit it 😉
Plus with a chain guide (mrp g2), I can continue to put the power down when it gets really bumpy..
Posted : 23/03/2012 10:12 am
Pretty much what geetee and xiphon said. I haven't had a front mech for over 3 years now, and can't really see an occasion when I might want one. My initial main reason wasthat I hate front mechs because I am shit at maintaining/aligning them.
Its quite ridiculous to claim it is some new stw fashion to do this when people have been riding 7-8-9 speed for years. Its only gears for christs sake.
If it is steep enough for a granny ring, I'll probably walk it. Managed 26 miles with over 3000 feet of climbing on Sunday (not in a trail centre) and didn't feel undergeared.
Posted : 23/03/2012 10:20 am
I only realized how lazy i'd got as a rider when i changed to 1x9. I'm not very fit, but have very rarely found an incline i can't get up, so don't miss the granny ring. Although this is helped by running a significantly lighter bike than normal.
Posted : 23/03/2012 10:26 am
And FWIW, I run 32t front, 32t-11t rear.
In the days gone by, the only way to run a single front ring, was via a heavy DH specific chain device. ( Remember the sandwiched MRP plates + rollers?)
Single MRP/e13 have developed their G2/LG guides, the weight has just fallen off, increasing the appeal to trail bike riders.
Posted : 23/03/2012 10:39 am
For the riding I like to do most a front mech is a liability... with a bit more effort and grunting I can make the 1x9(10) drivetrain do all I need, except for the really big stuff where I use a Hammerschmidt to get me a low winching gear.
If 1x9(10) works for where and how you ride then it's brilliant. My local forest is a bike wrecker and having strong kit with as little to go wrong as possible is sensible. Losing the front mech makes a huge difference as it really is a frequent cause of problems.
For me singlespeed is the ideal drivetrain as there is little to get damaged and bounce off; but it doesn't work well where I ride unless I am in the condition of my life, it's dry, the bike is 20lbs for the climbs... but still built for the descents. So for me singlespeed is too much of a compromise to be my main use bike.
I've tried a Rohloff in Gearbox and hub options but they were not the answer for me.
Next logical step is 1x9(10) since you get a good enough spread of gears for most riding. Yes, you no longer have the winching gear for huge climbs and the big gear for the road home but I'm happy to pay that price on my hardtail (which I mainly use in the local forests).
For a 1x9(10) type chain security but with a bigger spread (i.e. the low winching gear) for the big days in the hills I have a HammerSchmidt on my big bike... it's not as weighty as people think and it works brilliantly, I've never lost the chain off the front (despite losing the funky plastic guide ages ago).
Posted : 23/03/2012 10:46 am
has anyone got any weight save data? i am considering trying 1x10 on my heckler.
i already have a e13 chain device and an ally 32t chainring. do i have to use a shorter cage rear mech, or can i just take some chain links out and carry on?
so i guess i will save the weight of:
shifter
cable inner and outer
front mech
4x granny ring bolts
granny ring
big ring
difference between an xt middle ring and a renthal ally ring
several links of chain
and add
chain device
and, i get to put the reverb remote under the lh bar
Posted : 23/03/2012 10:47 am
I recently went from 2x9 to 1x9/ Removed my left hand XT shifter, XT front mech, cables, inners and bolts and it weighed about 340g.
Posted : 23/03/2012 10:56 am
I've never had a problem with a front mech out on the trail in over 20 years (plently of problems with rear ones, though). I can't believe that up here in t'North a 32 ring with an 11/32 cassette would suffice. You lot must be rock 'ard.
Posted : 23/03/2012 11:00 am
I find 1x10 spot on for my riding. I think I'd find the narrower 9 speed cassettes a bit limiting, I run a 36t ring with 11-36, a little bit spinny on the road, but fine otherwise.
Posted : 23/03/2012 11:02 am
 trb
Because my bike used to be a singlespeed, but I needed gears to carry a kiddie seat and it was only supposed to be temporary and I was too lazy to put the front rings back on.
4 years on the kiddie seat has moved bikes and it's still 1 x 9
But I do have another bike with proper gears on for when I go to places with proper hills.
Posted : 23/03/2012 11:04 am
I was having issues last night with a simple top 1x9 guide. It's been fine all through the winter but the ground was solid last night and I was riding really hard so the chain bounced off a few times... time for a full top and bottom chain guide.
Posted : 23/03/2012 11:07 am
Like failedengineer, I've been riding for about 15 years and [u]never[/u] had a problem with front mech's.
I understand why DH'ers don't use front mechs, but don't see the logic in pretty much everybody else not running one.
There's a couple of comments about "if it's too steep I'll just push it". Surely thats what a single speed is for?
I've also ridden singlespeed so can see the other side of the coin, as it were.
Isn't it just SS lite?
Posted : 23/03/2012 11:18 am
flatfish - I only use a single ring up front. If I ride uphill in a granny ring, I just spin like a whisk... while not actually gaining much ground. It's faster/easier to walk, while pushing the bike. Nothing wrong with that...
Also, without a bottom roller, my chain just bounces off...
.. hence the use of a single ring chain device 😉
Posted : 23/03/2012 11:32 am
What chain guides do you lot use?
Don't on-one have a nice basic one that attaches to the seat tube?
Posted : 23/03/2012 11:42 am
DH = SuperStar Laser
AM = MRP G2
Posted : 23/03/2012 11:46 am
My front gear cable snapped once on a ride. I jammed a stick in the front mech, using middle ring only. 18 months later the stick fell out. I removed components and went 1 x 9
Posted : 23/03/2012 11:49 am
 GW
been running single chainring set-ups on my mtbs for nearly 20years too, personally I only run 1x8 and 1x7 on my DH bikes (5 gears would be enough for a race bike). I absolutely hate the extra chainslap you get from anything bigger than an 11-28 cassette when descending in the smaller sprockets it'd be horrible with enough chain for a 36T sprocket flapping about.
Posted : 23/03/2012 11:53 am
Nae use to me. Switching to a single ring for me would be a compromise I don't feel the need to make. I enjoy steep, nose of the saddle climbs as well as the flexibility to just spin when I need to. If it works for you, great but for me it's a solution to a problem I don't have. I'd love a hub gear that doesn't weigh a ton and is reliable but until that arrives, I'm happy to keep with the triple at the front.
Posted : 23/03/2012 11:59 am
It's made me a stronger and quicker rider, especially uphill. Have yet to find something I can't ride up with 32t 11-34 if I attack it appropriately.
Posted : 23/03/2012 12:04 pm
 GW
pretty sure most of us could find you something fairly easily chief.
do you just not ride properly steep or technically challenging climbs or climbs with damp/wet/loose surfaces?
Posted : 23/03/2012 12:12 pm
I only ever used the big ring to keep chain tension on rough stuff, so that was first to go. Then the granny ring went when I found I used it so rarely as to make no difference. Chuck that stuff off bike, lower weight and less faff and clutter. WIN!
Posted : 23/03/2012 12:16 pm
 DM52
I didn't have all the parts when I built my hardtail up for 3 x 9 gears so ended up with a 1 x 9. So far so good.
Posted : 23/03/2012 12:28 pm
porter_jamie - Member
I worked it out at the time (massive nerd that I am) based on quoted weights, and it saved me about 330g.
Posted : 23/03/2012 12:46 pm
Just sold me 1x9 so just got a couple of singlespeeds.
I like 1 x 9.
Posted : 23/03/2012 12:47 pm
Saved about 370-400g going to 1x9.
Now run a e-thirteen G ring and bbg bash and jumpstop = 120g or something.
Posted : 23/03/2012 12:48 pm
 GW
you simply need to subtract the weight of all the components you ditch and add the weight of those you're adding.
could be as much saving as 2lb, as little as none.
Posted : 23/03/2012 12:49 pm
What he said and because its cool.
Posted : 23/03/2012 12:52 pm
because its cool.
... and because it makes people ask me why I'm riding a bike like that which means I can explain to them in detail about it in the car park at the trail centre instead of being up on the hill riding my bike (with 3x9 obviously... ) 😆 .
Posted : 23/03/2012 12:59 pm
Getting of and pushing is a defeat for me :() It's why I gave up on the s/s). Same with a 1/9 set up round by me, theirs far to many steep technical climbs for me to do without a granny. I like to feel some resistance when I'm pedaling on descents as well, so I need the big ring for that. But each to their own whatever works for you.
Posted : 23/03/2012 1:06 pm
works for me on a light hardtail... i already had 9speed stuff so just a case of not fitting LH shifter. also, it's nice not having to think about that shift or getting the surprise when you're not in the front ring you thought you were. downsides.. not quite enough range now i've put summer tyres on but i don't care about speed on roads any more.
Posted : 23/03/2012 1:26 pm
I went 1x9 on my 29'er over winter as the front mech was just a shelf for crud.
To be honest there's nothing I've ridden on it yet that will make me put a front mech and another ring back on.
Set up is 32t front and a 12-36t rear on a 29'er. awesome innit
Posted : 23/03/2012 1:40 pm
If I had the legs for it I'd do it, but I've not. I can however see all the benifits.
Posted : 23/03/2012 2:46 pm
fathomer that is why I have done it - to encourage me to get fitter/attack rather than spin in granny. If I don't get fitter and it effects my riding for the worse then I will stick the granny back on...
Posted : 23/03/2012 2:53 pm
Why clutter your bike with equipment you dont need or use? 1x works very well indeed if your rides are not too epic, and it loses significant weight, faff and expense.
"Isn't it just SS lite?"
Sort of yes.
I have a front mech (dual ring) on my other bike. It works OK and it's nice to have a granny ring to spin when your legs are in shreds. But I always found the mechs awkward to setup right - noisy etc. And they are terrible mud traps. Also, the gap between rings traps filth badly. Having a single ring is a much cleaner setup IME.
I've been using a E13 Hive top-only guide which works well for XC - just remember to keep your chain as short as possible.
Posted : 23/03/2012 3:20 pm
Page 1 / 3
