More seriously, I run 33 x 11/36 on one of my bikes and, to be honest, where I live it’s mostly fine. Low enough to get up most things, slightly under-geared on road descents, but I can live with that, so I guess I could fit a 40 on the back and then increase the size of the chainring which would give me a similarly lowest gear, but a higher top.
Or I could stick with the 33 chain-ring and have a lower bottom gear, which I probably don’t need. But in either case I end up with a biggish jump somewhere in the middle of the cassette.
I don’t think I need a lower gear anyway – maybe if I lived somewhere hillier than the Peak – and I’m quite a normal, regular kind of rider and if I did live somewhere with really steep climbs, I’d probably just have a triple or double anyway.
I guess the bottom line for me is that:
1. I’m not sure why you’d need either a lower gear or a wider spread of gears, off road at least.
2. It’s not like like having a single front ring is so astonishingly brilliant that I wouldn’t just put up with a few hundred grammes of extra weight and simply fit a front mech, shifter and another chain ring or two.
I’m amused that people seem furious over the whole wheel size thing, but SRAM’s extortionately priced 1×11 system and the aftermarket’s attempts to replicate the range with a 10-speed cassette, also at highish prices – add in those wide/narrow rings too, seems to fly completely under the radar.
Why’s SRAM’s stuff in the area so expensive? A cynic might think that if it were affordable, it would mean selling fewer cranks, chainrings and shifters, so the price is artificially inflated to keep things nicely profitable.
I should get out more…
