I had to tweak the negative terminal on one of the Stages I had, but it only needed doing once.
I’ve justed returned the 4th replacement I’ve had. It had the latest firmware on it. The first battery out of the box lasted about 3 months (about 100 hours riding) and then the next battery only a week. And so on and so on. Now the batery is only lasting 24 hours, goes dead from one session to the next. I occasionally get two sessions out of it.
It is powering down/stops transmitting after a period of inactivity and comes to life again with motion. But leave it for 24 hours and it won’t reawaken unless I put a fresh battery in. Then its fine again….for 24hours or so…. I’ve tried Duracell, Panasonic, Maxell, cheapo pound shop batteries and no difference.
If someone could just tell me what I’m doing wrong I’d be chuffed but who knows….
Exactly the same symptons as mine. I suspect it is water ingress.
I removed the battery cover just before sending it back and there was a drop of water on the battery. I had checked for ingress when it started playing up but none was evident.
Apparently the Mk2 is identical (pcbs, strain gauges, software etc) apart from the plastic housing – that tells me something!
