I am building up a 29+ bike which will have a Rohloff, and I need to choose a chainset, threaded bottom bracket, and suitable chainring size.
As I understand it, many people with a Rohloff use a Shimano triple chainset with just an outer ring, since the outer ring has the required 54mm chainline for the Rohloff. Rohloff actually supply the hub with the narrower chainring bolts needed to convert a Shimano triple to a single ring.
Although I imagine there are some boutique brand chainsets which would work well with a Rohloff, such as Middleburn who made a Rohloff specific spider for their cranks, I suspect that they do not offer a worthwhile advantage over using a converted Shimano triple.
The obvious choice therefore would seem to be a Deore, SLX or XT triple, but I do prefer the square taper bottom bracket design, and so I wondered about getting a cheap Acera triple chainset and using it with a high quality square taper bottom bracket such as SKF, Phil Wood or Royce. However, I suspect that a Hollowtech chainset – possibly with a better quality bottom bracket, e.g. Hope – would still be the most sensible option for performance, reliability and value.
I would be interested to know if others would agree with this or have any alternative recommendations.
