Slightly different geo between sync & ff29
Similar but not the same…
Having owned a Sync, I was very impressed at just what a 29er with a 70 deg HA was capable of. It never felt too steep or out of its depth, and I took it down some fairly tech descents in the time I owned it. The 7mm reduction in chainstay length over the FF29 is quite noticable when you ride it too.
FF29 has indeed now been discontinued. Have a small frame for sale in black, about 20 rides old, belonged to my GF before she bought a Stanton Sherpa, if anyone is interested…
If the FF29 had 435mm chainstays I’ve buy one over a Stanton myself.
There are other differences than just the chainstay length… Being a geometry bore, and having had access to the bikes (and measured them properly) I can tell you that the FF29 has a static 71deg HA with a 120mm fork fitted. The Sherpa is over 4.5deg slacker, with a sub 66.5deg static HA with the same 120mm fork fitted, or is still only at about 67.2deg static with a 100mm fork fitted. The Sherpa’s BB is also slightly taller (the only reason I’m not already riding one, as I like my BB height down in the weeds).
This is why I’ve just bought a Whyte 629 complete bike to strip for the frame… Similar sub 2kg weight as the FF29, chainstays at 440mm aren’t mega short but usefully shorter than the FF29’s, HA is sub 67deg static with a 120mm fork (the 68.5deg quoted on Whyte’s website is for a 100mm fork with a Zero Stack bottom cup, not an external required for a tapered steerer), ETT and reach figures are nice and long so I can run a nice 50mm stem on a Medium for my preferred position, and they’ve lopped 25mm off the seat tubes this year to make 125mm droppers more easily accommodated. Oh, and even with a 120mm fork and 2.3″ tyres fitted, the BB height is still only 308mm! Happy days…
