Where to buy fluid ...
[Closed] Where to buy fluid for Fox forks
[#388566]
i have a set of 2007 Fox 36 Talas RC2 forks and after popping off the top seals it appears that the wipers are a little bit on the dry side and require some fluid.
What fox fluid is required and where do i get it from as CRC, Wiggle etc do not appear to stock any?
Posted : 13/03/2009 9:52 pm
Google Mojo Suspension.
Posted : 13/03/2009 9:59 pm
ok have worked out i can now get fluid from TFT/Mojo but what type......2.5/5/7.5 or 10 wt,
Posted : 13/03/2009 10:06 pm
Fox use 7wt in the lowers...
Posted : 13/03/2009 10:08 pm
There's a chap on wiki called pdv or pvd. He's got a chat that shows the actually viscosity of various fork oils. From that, you can look up the fox stuff and see what it really is and buy it cheaper from a car or motorcycle shop. I think the 10 wt is silkolene amd the 7 wt is Torco.
Posted : 13/03/2009 10:14 pm
I think Mojo recommend Float Fluid for the foam rings, it's different to the fork oil used in the lowers.
Posted : 14/03/2009 9:30 am
The [url= http://www.peterverdonedesigns.com/lowspeed.htm ]site[/url] mentioned above makes some mention of float fluid being Torco assembly lube if I remember correctly. having said all that, the Talas 36 is a cartridge fork so you're really just talking about keeping the insides lubed rather than damping duties, in which case, almost anything is better than running them dry!
Posted : 14/03/2009 10:15 am
Maybe, but since the forks should be kept upside down does it really matter? Would the fluids not just mix?
Question i have is why do fox reccommend a quite light oil in the lowers (7wt) when other manufacturers use 15wt+. It would seem to me a heavier oil in the lowers would be better and help it 'cling' to the internals as the fork works.
Posted : 14/03/2009 4:21 pm
Fox 7wt is Torco RSF Medium.
I have read of folk using sae 80 gear oil instead of float fluid. I just used the fork oil as its definitely better than dry foam rings.
stuartanicholson, heavier oil will mess up the damping.
Posted : 14/03/2009 5:43 pm
In the lowers? Your joking?
Posted : 14/03/2009 5:48 pm
Sorry, damping oil is separate on fox 😳
Posted : 14/03/2009 6:01 pm
Fox float fluid is Torco 75wt gear oil.
Posted : 14/03/2009 6:37 pm
where does fox recommend forks to be stored upside down?
Posted : 14/03/2009 6:49 pm
To keep the foam rings lubed. Storing upside down lets the oil in the lowers run down and soak the rings.
Posted : 14/03/2009 11:40 pm
