Where should my HR ...
[Closed] Where should my HR be, roughly?
[#3800297]
I've never kept records about HRs, and this week I set off on the Time Crunched again.
Whilst doing the 3x10 minutes sessions that are meant to be at about 92% of max, I could only sustain a rate of about 150 bpm. Of course I could get it up higher in peaks, but the 150 mark was all I could sustain over the three ten minute intervals.
That's way off where I need to be isn't it? Pretty sure I got nearer 170+ last time i.e last year just before cross season.
Posted : 22/03/2012 9:14 pm
As we are all individuals and there can be no hard and fast measure, the only person who can tell is you.
By keeping records......
Posted : 22/03/2012 9:18 pm
the appromation used is 220 - your age for max rate then you want 92% of that,
However that is a generalised approximation only
Posted : 22/03/2012 9:20 pm
Started on TTCC plan again last week too, comparing a 3x12SS session I did this Tuesday and one I did last August I'm 5BPM lower on average HR now but 500 metres up on distance for the session 🙂
Have you done the CTS Field test again prior to this training plan, it's no good going with the values you calculated last year.
Posted : 22/03/2012 9:36 pm
Mine is on the same floor as Finance and Payroll
Posted : 22/03/2012 9:39 pm
Chapeau sir!
Posted : 22/03/2012 9:40 pm
Have you determined your actual 100% hr? Not the theoretical
Could be you are ill?
Could be you are overtraining/tired?
Lots of possible reasons
My max on the bike was 170, could sit all day at 135/140. Resting is around 50. When I had an ECG recently it showed I was fit as a fiddle but thr Doc was concerned at how low my hr had dropped during the test!
Playing squash = 180
57btw, currently restricted by dodgy knees, back, asthma and a few other issues!
Posted : 22/03/2012 11:27 pm
