What's your best DH...
[Closed] What's your best DHing tip???
[#641273]
Getting focused on doing some more DHing and improving my fast / technical skills.
What one (or maybe more) tip(s) would you pass on in your experience?
Posted : 17/06/2009 5:23 pm
 Kuco
Don't crash 😉
Posted : 17/06/2009 5:25 pm
PEDAL!
Posted : 17/06/2009 5:28 pm
 Doug
Follow someone slightly quicker than you. When you get as fast as them, find someone else to follow.
drop the saddle low.
Posted : 17/06/2009 5:29 pm
Stay off the brakes.
Posted : 17/06/2009 5:30 pm
your bike is capable of more than you are
Posted : 17/06/2009 5:32 pm
Look up, not down. (not literally) 😆
Posted : 17/06/2009 5:34 pm
Eating lots of hormone-laden processed meat will give you the necessary aggression.
Posted : 17/06/2009 5:37 pm
Focus your mind, relax your body, improve your reaction times and fitness. Practice individual skills one at a time. Get someone to give you constructive criticism.
Posted : 17/06/2009 5:38 pm
Check your armour is doing its job by getting someone to administer round-house kicks to various parts of your body.
Posted : 17/06/2009 5:41 pm
Do chainless runs and learn to pump the trials.
keep your weight central.....not far back..
Posted : 17/06/2009 5:42 pm
One finger braking
Dont hang on for dear life
The bike will make it even if you dont think it will
USE the bike to get down the hill, dont just be along for the ride.
Posted : 17/06/2009 5:44 pm
Stay loose! Dont rely on your suspension to do all the work, Move about and try and make the bike flow over/around obstacles, pick the smoothest lines possible,
Completely disregard that voice in the back of your head that says "I could get hurt", "What happens if", "Should I", "What are the risks" etc etc. Its when you doubt yourself you end up crashing.
Also the faster you get the easier it is!!
Posted : 17/06/2009 5:45 pm
go high on off camber roots relax your wrists and ankles and let the suspension do the rest
carry your speed less braking more pumping chainless is a good idea is an eyeopener too
 Kuco
pick your lines carefully.
Posted : 17/06/2009 5:46 pm
learn to pump dips and berms and manualling dips and little rooty bits, learn to unweight the bike so you can clear rocky/rooty bits and little jumps without losing time getting too much air. Basically learning to carry as much speed through/over obstacles as possible as it can often be hard to get much pedalling in over the rougher stuff. Ride to the edge of control, you will slide out and go down a few times but tbh that's part of the learning curve.
Posted : 17/06/2009 5:47 pm
 v10
Dont brake in corners or off camber, let it roll and it WILL grip.
Look well ahead and also where you want to go, if you look at that big evil tree stump you will naturally ride into it 😆
Relax, let your arms and legs work with the suspension not against it.
Also a fine line knowing when to let the bike have its own way and when to reign it in and correct it but you cant really teach that.
Posted : 17/06/2009 5:50 pm
All good, I was thinking earlier while riding that I always look about 2-3 metres infront of the bike so I tried looking about 10-15m ahead and ignore the state of the trail directly infront and I just flowed over it. Felt great!
Posted : 17/06/2009 5:56 pm
wear lycra
Posted : 17/06/2009 6:00 pm
practise. Ride the same sections over and over. Try new lines. Follow the lines of the fastest riders. Keep the bike setup as you want it, not what you think it should be.
Posted : 17/06/2009 6:02 pm
- pump and learn to keep the bike on the floor as much as possible.
- lean the bike hard into corners.
- look ahead
- 'session' the same run.
- follow good riders
- sounds silly but... don't brake (or brake less)
Posted : 17/06/2009 6:11 pm
 jonb
Turn off your fear.
Posted : 17/06/2009 6:48 pm
relax, get loose, you will stay higher longer
Posted : 17/06/2009 8:42 pm
 jedi
enjoy it
Posted : 17/06/2009 8:46 pm
Ride.More!
(Not implying that you don't ride enough or anything!)
Posted : 17/06/2009 8:47 pm
Cheers for the advice - had a good ride about an hour ago, whizzing down the techy runs round me!!! feel like I've improved overnight!!! 😉
Posted : 18/06/2009 1:11 pm
watch freeride downhill videos to get pumped before hand - seasons is a favourite.
Posted : 18/06/2009 1:15 pm
Block from your mind the crippling arthritis in later years from all those broken bones and dislocations as you set yourself up for that next jump.
Posted : 18/06/2009 1:19 pm
 Olly
Relax, dont tense up
Do lots of it 🙂 ...and try and be relaxed and smooth.
Posted : 18/06/2009 1:20 pm
Much, much further ahead. To the horizon, literally. Head up with your eye-line level.
If you're going to have a go properly why not go for a proper coaching session? Several top downhill riders have done the CTC instructor course - Rowan Sorrell for one, plus plenty of others. Not sure where you are based, but Llandegla is good for that.
Having said that, if you're used to looking only a couple of metres in front of the bike then a more general skills session would be a better place to start. I hear there's a good outfit working out of Surrey Hills...
Posted : 18/06/2009 1:21 pm
I've had a few wipe-outs that would disagree with you there!
Posted : 18/06/2009 1:22 pm
I've just bought my first Full face helemt for a bit more confidence when pinning my local triple black pirate trails.
Trying to jump far enough to get a good smooth landing like the big boys, carry more speed through corners, not slowign down before technical bits. Confidence and practise is the key.
Learn to pump the ground, also pump through berms. Keep your weight on your outside pedal in flat or off camber corners, unweight the bike over roots. Walk the course and watch elite / expert riders to find the best lines. Don't drag the back brake, brake with the front brake just before corners. Learn to jump!
Posted : 18/06/2009 1:37 pm
Make sure you are wearing this season's best gear. Its all about how you look 🙂
Ride a lot, don't take it to seriously, laugh, do it on your own and with friends, enter some races, mix it up, drop, dodge, dive, drop and er dodge.
Posted : 18/06/2009 1:48 pm
Guys - thanks for the advice.
I should say I can handle a bike, just haven't done much DHing before as roots, off camber and steep scare me a little. But from the skills I've got already I feel I should be able to adapt easily...
[img] ?v=0[/img]
[img] ?v=0[/img]
[img] ?v=0[/img]
Posted : 18/06/2009 1:53 pm
Buy a red coloured bike. Red bikes are faster. FACT.
Posted : 18/06/2009 1:55 pm
Buy a fantastic bike that's totally wasted on you and hope that makes you better. At least, that's what I'm going to try this summer.
Posted : 18/06/2009 1:57 pm
 5lab
tyre pressures and saddle right down. I run 15 psi and it grips like a bad rash
Posted : 18/06/2009 2:00 pm
David_r - can I just spray mine red - will it be faster then?
Posted : 18/06/2009 2:35 pm
Wear bright orange trousers and top
Posted : 18/06/2009 2:38 pm
Apologies - you misled me with the looking thing. Hope you don't mind me saying, but all of your riding will be transformed if you start looking way ahead and stop inspecting the ground in detail. It is quite surprising that the very first thing we teach novices comes very late in the day to experienced riders.
Posted : 18/06/2009 3:28 pm
I've got a red bike 😀
I think the distance you look ahead should be qualified. Basically the distance varies according to the speed. so 3-4metres is probably about right up a steep hill in Granny, but coming down the other way it could be 25-30 metres.
Perhaps looking 2-3 seconds ahead is a better description?
Posted : 18/06/2009 4:35 pm
