Front of a bus will get completely covered in bits of tar from the road which can be a tricky to remove. Even trickier if you’re in a show field. Drive up with it on, take it off to show the vehicle. That’s the idea.
People run them as they like the different look it gives but the primary purpose is for protection.
I had a visit to the McLaren factory and they use that tape to protect the new cars on the initial test drive before it’s signed off as ready for delivery.
I don’t think that Golf is on its initial test drive.
Shirley those vinyl bra jobbies will have a lot of dull paint as a result of water and grit getting underneath then vibration and movement causing scuffing and abrasion of the paint?
It’s certainly happened with phone cases: take a plastic case off a phone after some time and you find lots of little dull spots where grit works its way underneath then acts as an abrasive through movement.
Clear vinyl film applied to the car will give much better protection without looking stupid.
Those extended wheels seem to be very popular with older MX5 owners for some peculiar reason as well…
The paint not covered will still fade and the wraped part won’t.
Paint protection film will filter UV. Helps to stop stone chips to a degree, though.
We recently wrapped a 968, which was red, had turned pink due to UV.
The parts which had the stone protection film on were perfect underneath.
Effects your MPG less than a bra though. Guessing I’m missing the point there though!
