Last year’s SID RLT Ti in 120mm 15mm axle here. Light, stiff (for the genre of fork) pretty cheap compared to the equivalent FOX. I’m pleased as punch, reasonably easy to setup, they work so well that I forget they are doing their job.
Only down side on mine is that the -ve air sometimes sucks down a little into the travel over time, then when resetting pressures there’s always a small sppirt of oil from the -ve valve. Nothing a decent service wouldn’t fix, just waiting for the spring clean to happen 😉
edit: In limited back to back testing against a FIT 32 on a friend’s trek, I think the SIDs are a little more plush. To be honest there wasn’t much in it. So, cheaper and lighter and otherwise doing the same job; what’s not to like?
