Ti Seatpost + Ti Fr...
[Closed] Ti Seatpost + Ti Frame = Recipe For Disaster?
[#3614456]
Looking to replace my alloy post with a ti one for a bit more flex.
Anyone encountered any problems with sticking? Can \i get away with my usual copper slip for lube?
Posted : 27/01/2012 12:59 pm
After 3 years I've had no problems. Using frame manufacturer's own seat post. I think it's some sort of ceramic grease that's been used.
Posted : 27/01/2012 1:05 pm
[s]i think there's a reason you can't use copper slip for it. could be wrong, though![/s]
that's not true, it appears!
Posted : 27/01/2012 1:07 pm
Ive had no probs with an eriksen in a lynskey on-one.
Light smearing of grease when I can be bothered.
Posted : 27/01/2012 1:11 pm
Not sure why you would need any lubricant, titanium doesnt react much and is highly resistant to corrosion it shouldnt be sticking.
Posted : 27/01/2012 1:13 pm
haven't had problems with mine on a djab
which i could be selling as i'm splitting the bike 😀
Posted : 27/01/2012 1:16 pm
 Rio
Been using an Airborne Ti seatpost in an Airborne and then an On-One Ti for nearly 10 years and never had a problem. I don't use any grease as it tends to make it slip down unless you use unreasonable amounts of torque on the clamp bolts. I am very heavy though!
Posted : 27/01/2012 1:17 pm
 aP
Titanium/ titanium can have problems of galling, so use a metal prep grease.
Many Ti frames use alloy shims so no great issue.
New Van Nicholas ones do use a welded ti insert though.
Posted : 27/01/2012 1:37 pm
 br
I run a carbon one in mine, very comfy, but I can't get it out...
And won't be forcing it until I have to.
Posted : 27/01/2012 1:39 pm
Carbon in a Ti frame here too, very comfortable indeed.
Posted : 27/01/2012 1:47 pm
aP - Member
I doubt it, shouldnt be much movment between te surfaces.
Posted : 27/01/2012 3:18 pm
 JoeG
My Ti Merlin has an Al insert built into the seat tube.
Posted : 29/01/2012 3:37 am
Pay careful attention to what sc-xc says:
http://singletrackworld.com/forum/topic/comfy-seatposts
Posted : 29/01/2012 7:07 am
Titanium and aluminium in contact together can result in significant galvanic corrosion of the aluminium. With the corroding aluminium swelling up and doing damage like this:
http://pardo.net/bike/pic/fail-001/FAIL-102.html
Titanium in direct contact with titanium, with the two surfaces rubbing, sliding against each other can result in galling (cold welding). MoS2 molybdenum disulphide.
http://www.sandsmachine.com/grease_t.htm
Titanium against titanium can also cause problems with fretting.
http://www.ewp.rpi.edu/hartford/~lessam/Project/OTHER/1%20Reference%20Materials/SELECTED%20FRETTING-WEAR-RESISTANT%20COATINGS%20FOR%20TITANIUM%20-6-PERCENT-ALUMINUM%204-PERCENT-VANADIUM%20ALLOY.pdf
Posted : 29/01/2012 8:12 am
Had a ti moots post in my ti ibis for about 11 years. Just keep in well greased and check annually.
Posted : 29/01/2012 10:30 am
Any particular grease to use or avoid? I've used copper grease on my Ti frame with Ti seat post with no visible problems.
Posted : 29/01/2012 10:41 am
Posted : 08/02/2012 9:01 pm
The experiment uses Titanium and Aluminium tubes of the same diameter [b]and thickness[/b]. A Ti seat post will have significantly thinner walls than an Aluminium. A Ti seat post will be designed to allow for some flex. To a certain extent flex in Aluminium has to be engineered out, due to material fatigue from repeat stresses.
Posted : 08/02/2012 9:22 pm
