The Spidereye ... i...
[Closed] The Spidereye ... it doesn't half sit there and look at you ....
[#3652926]
Arrived this morning ....
As already mentioned in another thread ... it just sits there ... looking at you. So cute.
Its also bleeding bright ! I'll take it out for a ride tonight and see how it goes. Well impressed so far.
Posted : 07/02/2012 3:35 pm
those bricks holding your rotary washing line down could do with a clean.
Posted : 07/02/2012 3:36 pm
what's the little lens under the "eyes" for?
Posted : 07/02/2012 3:37 pm
The eyes create a long narrow square beam with a very sharp cut off.
The little ones create a wide flood area below that in your near distance from the bike.
Posted : 07/02/2012 3:40 pm
johnny 5!
Posted : 07/02/2012 3:46 pm
I know it's been designed as a helmet light but would it be completely crap attached to handlebars?
clever...
they do look good. How much do they cost?
Posted : 07/02/2012 3:47 pm
I can't decide which one it looks most like:
Posted : 07/02/2012 3:48 pm
Muppetwrangler
Absolutely great as a bar light but I have not designed a bar mount for it yet .
Posted : 07/02/2012 3:52 pm
Slacker!
On a more serious note. Are you going to design a bar mount for it and if I were to order one soon(ish) would I be able to get the bar mount at a later date?
Posted : 07/02/2012 3:53 pm
Trout, whats the cost of these? full system with larger battery and charger?
Posted : 07/02/2012 4:01 pm
trout have emailed you can you let me know asap thanks
Posted : 07/02/2012 4:09 pm
Chris, can you please check your junk mail folder. My email may be in it.
Ta
Posted : 07/02/2012 5:08 pm
Regarding the bar mounts, I was considering using a couple of the lumicycle bar clamps I have to make a couple of simple arms that stick forward that the helmet mount can then velcro to in the same way it would attach to the helmet.
That way, its an easy swap between bikes ( Roadie and CX bike have oversized and the commuter and FS have normal sized. )
As for costs ... rather than trout doing blatant advertising on the forum which some frown upon, if you look at his profile there is a link to his website and all the info is there.
Flashy
Last email I can find from you was dated 31 jan and I think I replied .
checked everywhere .
will have a look and see how easy it would be to do a bar mount got a few ideas floating around
Posted : 07/02/2012 5:36 pm
 jimw
As a temp or even more permanent measure for a handlebar mount it looks like you could bolt to one of these:
http://www.chainreactioncycles.com/Models.aspx?ModelID=23533
that is what I have done with my Hope vision2 (first model) which looks like it has a similar mount- if you remove the helmet mount and bolt it through the hole with a good washer on one side it holds onto one side of the 'L' shaped fitting on the clamp. Works very well
Posted : 07/02/2012 5:55 pm
Posted : 07/02/2012 5:58 pm
Barmount is easy just need to tweak the mounts I used for the Liberators
and persuade my machinist to run me a few off
so to answer muppetwranglers question yes bar mounts will be available later on
Posted : 07/02/2012 6:42 pm
 mega
Wow - that looks (ahem) brilliant
We need a skull with lighty up eyes next please 😀
Posted : 07/02/2012 6:51 pm
That is crying out for a custom paint job on the faceplate.
Posted : 07/02/2012 6:54 pm
The lights glow in the dark after they have been on:
Max mode is stupid bright, although it gets warm pretty quickly on the desk at that mode and will auto-reduce to the mid-setting ... which is more than enough to see by. Still to go out and about with it, but i think it'll need the air-cooling of being on the bike to be able to run at max for longer periods. .
Posted : 07/02/2012 7:54 pm
Chris,
Re emailed...........
Posted : 07/02/2012 8:35 pm
The bottom led's need a bit of luminous paint on them too. Imagine the look of that at night switch off on a trail in the middle of no where 😯
Posted : 07/02/2012 10:53 pm
Not exactly the best intended set up, this is just me lashing a demo together!!!. Thanks very much to Chris/Trout for the opportunity of a demo of all his new lights. The Dominator demo was awesome (in December), but I just had to compare it to the latest Spider Eye light. All set up for our Wednesday night ride and the big test (hopefully not many trees on this test). Probably already sold on the Spider Eye if there are options to interchange it to head mount, bar mount, head torch etc. Difficult decision, the dominator is brilliant as well
Posted : 07/02/2012 11:34 pm
OK an apology is in order Just back in from a test ride with it on the bars and I dont like it just to many shadows in hi definition
its not floody enough for the bars imho
Awesome as a helmet light though 😯
Posted : 08/02/2012 8:20 am
I don't care how it performs - it just looks super cool.
Posted : 08/02/2012 9:56 am
 juan
Seems a bit big for a helmet light, but I concur, it looks so cool.
Posted : 08/02/2012 10:05 am
can't see a price for them on the website - usually an indication that I can't afford it. Nice looking light though!
Posted : 08/02/2012 10:06 am
Big No
Posted : 08/02/2012 10:10 am
 juan
ohh looks much bigger on the picture above. Sorry trout.
Posted : 08/02/2012 10:35 am
that guy must have a tiny helmet...
Posted : 08/02/2012 10:36 am
[i]ohh looks much bigger on the picture above. Sorry trout. [/i]
Yeah, I thought that, but the first picture, up top ^^ looks tiny in the hands of the OP.
I think the light looks larger in B.A.nana's pic because the light looks to be on a longer mount, holding it further from the helmet ?.
Also some perspective coming into play too.
I reckon it looks very small.
Like its almost all lens.
Posted : 08/02/2012 10:45 am
That is a comedy display battery 😉
Posted : 08/02/2012 10:49 am
You could do a more sinister paint job like a Mark 13 from Hardware.
Posted : 08/02/2012 10:52 am
TROUT - is your email address working at the moment? Only I know you've had issues before and I sent you a couple of emails.
Posted : 08/02/2012 1:39 pm
ditto.........
Posted : 08/02/2012 2:27 pm
Mr Trout, what are the Aspheric lenses on your website for? Are they to upgrade other lights with?
Posted : 08/02/2012 2:39 pm
[url= http://farm8.staticflickr.com/7026/6841096433_d6d42ca986.jp g" target="_blank">http://farm8.staticflickr.com/7026/6841096433_d6d42ca986.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/60440210@N04/6841096433/ ]Spider eyes[/url], on Flickr
Posted : 08/02/2012 2:46 pm
lol @ Rusty
Posted : 08/02/2012 3:00 pm
 juan
pmsl
Posted : 08/02/2012 3:06 pm
Lol @ Rusty 😀
I dave those are the lenses in the spider and also for sale to flashlight geeks they guy who makes the lenses is in Australia and wanted a distributor in europe
Flashy got yours this time and thinking of a reply
Sugdenr
looking for yours at the moment .
Posted : 08/02/2012 3:46 pm
Juan, I can confirm it's small and light (134gms).
My pic is of trout's own dog walking headtorch lashed onto my hat. I did actually think twice about posting the pic, as I thought it had the potential to cause some confusion. The headtorch mount in my pic isn't really meant for a bike helmet, makes it stick out and also the perspective from the close up makes it look bigger. I'm thinking about using it for multisport and just a general headtorch/lamp, it would possibly make a good caving lamp. this one here
Posted : 08/02/2012 4:26 pm
trout - Member
Is that just you being over critical or is it actually not good? is it possible to use the same body, but just have different lenses?
Posted : 08/02/2012 6:35 pm
Trouty - do you run a spider eyes with a bar light - or is it sufficiently bright to go it alone?
Posted : 26/02/2012 7:48 pm
