It looked to me that most of Contador's gains were the result of who he was descending with. Four or five guys sharing spells at the front will fly down. Schleck only had one other guy with him who looked spent and Vino' tagging along at the back.
Bike Forum
TDF Spoiler
Posted 1 year ago #
Do pro teams employ yts mechanics who cant set limit screws these days?
Posted 1 year ago # -
In years to come Contador, if he wins, will be remembered for winning the tour and this detail largely forgotten - maybe that's the way he sees it? Hopefully the booing has had an effect though.
Captjon - how does the chain falling to the outside suggest he had a chainwatcher on? Chainwatchers are designed to prevent the chain from falling to the inside/BB and possibly jamming.
Does AS run Rotor-Q oval rings? My concern with these is that at the lowest point of the ring there is a significant gap between the ring and mech cage giving the possibility for the chain to unship to the outside.
The picture in the link suggests Saxo Bank use them on their bikes. Is it conclusive the chain came off the outside?
xcstu - Member
2 words.. chain guard...
and he would still be in yellow? simple
Saxo fit chain devices to all their bikes.
And I spooled through ITV's coverage of the TDF tonight and I'm pretty sure Schleck wasn't on the shifters when the chain jumped off. He looks like he moved his fingers from under the hoods to shift after the chain jumped, probably to sort it out. The side shots showed a rear mech under light tension (ie small rings front and back) that then flicked backwards further as the chain suddenly unloaded. Schleck's drive on the pedals as it locked lifted the back end up a good 6", as Contador would've seen as he was behind when it happened. In fact, Schleck was barely pedalling when it happened.
I bet there's a ton of footage on YouTube now. Go have a look.
Both are on Specialized Tarmacs with SRAM Red, so I couldn't blame fancy electronics, either.
Yes and should be won fairly because you are the better rider rather than because your opponent had an unlucky mechanical.
Poor behaviour from Contador clearly worried but in yellow nowI agree in principal but since when was the TdF everyman for himself. Its just as much about the best team and the tactics they use as it is the best rider.
Either way I hope Contador just stops before the line tomorrow and gives schelck the 20 seconds back, then in teh time trial blows him away, to shut everyone up.
Posted 1 year ago #
Why is it 'not in keeping' with the TDF? Considering the well-publicised drug scandals over the Tour's history, is failing to slow down sufficiently to placate Contador's haters really that big a crime? Really? So you can elbow and headbut soemone in a sprint, but you can't keep pedalling at the same rate if somone's chain has fallen off, even if you might not be aware of that?
I think you fail to notice that the guy doing the headbutting was kicked off the race. Failing to notice is no defence as his team would have told him. You are clearly do not understand road racing if you fail to at least see the controversy in yesterdays stage regardless of your opinion on the matter.
You can't head butt in the tour, renshaw got kicked off (unfairly imo) but still you can't use it as an arguement!
AC should have just stayed with Sanchaz and Menchov and not attacked.
AS lost time on descent because nobody was working with him De Broek was knackered and Vino certainly was not going to help! 3 top flight racer a full tilt team trialing it to the finish it certainly going to be faster than 1 guy doing the work. He did well not to lose more time.
Will he attack today? Theres a long way to the finish that is the only thing. If not may well be a bit risky leaving it till thursday.
The chain catcher things on carbon bikes attach to the front mech. Doesn't work going off the big ring. From the videos his bike jacked up so either he fit a stone or something else went wrong. Probably those eliptical chainrings.
I imagine any of us would be a bit cack handed at putting a chain on. He's just been riding up a mountain on his limit after already done a couple of miles that day and a few the days before as well. I imagine he was feeling the pressure from being the leader in the biggest cycling event going. It's easy to flick a chain on under no pressure. But pressure changes everything.
The bike endo'd because the chain slipped not the other way around.
Schleck attacked, Contador followed. 's not Contador's fault Schleck fumbled his gear change...
Schleck didn't change gear... mechanical pure and simple which in TdF ettiquette means you don't attack. The question is whether AC realised and if he did, since Menchov and Sanchez were up the road, what he should have done.
The correct thing all round would have been for AC/Menchov/Sanchez to wait to AS to catch up.
Contador's changed his tune a bit from yesterday
Well done that man!
Even Riis wasn't that annoyed. bad riding skills brought on by pressure etc, look at the film, Andy was in top. Can't see Sanchez or Menchov stopping and then they would have been in yellow. well 1 of them.
In all the years I have always thought Ulrich a **** for waiting. How come none of you lot are moaning because no one waited for Armstrong when he puntured on the pave'? Same thing. Anyway Saxo have already pulled a dirty with Cancellara stalling everyone early on. Must admit to being an Andy fan but you can't go around blaming one rider coz another cocked up.Posted 1 year ago # -
I think he should have waited (Contador doesn't need Schleck having a mechanical for him to win the TdF so pointless taking advantage of it). However it's a fair point that Andy's previous time advantage came after Contador was held up on the stage 3 crash. If Contador had have said that as his reason for attacking it would have at least been honest, for him to come out and say he didn't realise Schleck had a problem at first is just BS. As is saying he had to stay with Sanchez/Menchov - they only went for it after Contador had attacked.
A chain device wouldn't have helped given how the chain came off either, it is a bit unusual though (I was wondering to if he uses elliptical chain rings and if they had a part to play but I don't think he does). He also did a half decent job of sorting it quickly, the problem was as he went to start off again he back pedalled slightly which threw the chain again as it wasn't fully on.
Tough one this but I think peoples views are swayed by whos camp they're in i.e the STW concensus is it's gloves off in a sprint attack, but Pimms 'o' clock in the mountains.
Am I right in thinking that Schleck is only where he is because of the Stage 3 fiasco. Then there's the mechanical, if it was a mechanical some are saying he rode over something. Then there's the twins in orange, they couldn't be ignored.
We'll see today I guess. Schleck might be regreting playing silly buggers the other day.
Pesonally I'd like to see Contador drop Schleck like a sack of spuds and have a good minute on him by Sunday.Posted 1 year ago # -
Post hoc ergo propter hoc
I reckoned the apology was reasonable. He put it down to a red-mist type event, which is understandable I suppose.
You mean the cack handed way he stopped, leaned down while still astride the bike and attempted to fix it, got back on, realised he'd not fixed it and finally jumped off waving his hands around.
If he'd have known what to do there he'd have lost about 15 seconds max, as it was he lost nearly 40.I'm assuming you could've done better?
Right when I attacked Andy had a mechanical on the last climb
No, Andy had a mechanical, then he attacked.
Don't you think the more you watch the video the more it looks like Contador was closing the gap anyway?
Because Armstrong wasn't in yellow, and it wasn't a decisive moment in the race?
My opinion of Contador dropped a bit today, seems pretty clear that Schleck was pretty much at a standstill when Contador shot past him so I don't buy that he didn't realise what was going on. Looks like Menchov reacted to that and then Contador was in an awkward spot. I'd have liked to see him wait though, if nothing else because it's disappointing we didn't get to see them going at it.
oldgit - yeah, I don't think AS was going to get away - AC had the measure I reckon but again, it seems to be pretty clear that AS was almost stopped dead when AC went past and since it's unlikely to be anything other than a mechanical, they (Menchov and Sanchez) should have held off - just as per when LA got caught up in that bag in 2003 and Ullrich et al all waited once they realised what had happened.
As someone mentioned earlier it would be nice for AC to give the time back to AS in some manor, if after that AC wins he will be remembered as a gracious winner and a good sportman, if AS was to win after that AC would still be remebered for the moment of fine sportsmanship which might pale AS's win a bit. If however nothing is done and AC wins he might just be in for a bit more booing at Paris and will be remembered badly if AS wins he will be touted as a god and AC the villan forever more... Personally I would like to see AS pick up the time lost on AC and go on to win the tour or AC to give back the time gained and then win.
Iain
Just to confirm - Contador wasn't the Astana guy closest to Schleck when he lost his chain was he?
He's the guy behind the guy?
To be clear AS lost half the time on the due to the mechanical and the other half due to the AC, Menchov and Sanchez working as a team to put as much time in to AS in the descent. AS did a awesome job and minimizing the loss considering he was alomost working on his own. AC may not have seen his chain come off, but you can be sure his team knew and would have pass ono the info to AC straight away. I think AC's youtube apology shows his guilty conscience?
thebunk- right, so he probably wouldn't have actually ssen Schleck drop his chain, but I don't think he could have missed the fact that there was a mechanical as he went past.
The more I watched it the more it became clear that as Contador sprinted up the road, Vino who was leading the chase slowed with Shleck and was on his radio, presumeably telling the team what had happend to Shleck so Contador cannot really say he didnt know, unless the team didnt tell him. It was very clear that Vino slowed and Contador didnt. And thats hard for me to say as I **** hate Vino, but he seemed to have done the "right" thing. Would be fascinating to hear if Contador knew what was going on or if the team with held the info.
Of course the other thing is that we're all saying "if he screwed up a gear change it's rider error and okay to take advantage of, but if it's a mechanical then he should have waited", closely followed by "having rewound the tape several times, I'm now certain Schleck didn't change gear" - without the benefit of a rewind button, how is Contador supposed to know what caused Schleck's problem. At the end of the day, he's going to have a few seconds to make a snap decision about whether it's appropriate to stick the boot in or not, at a critical point in the world's biggest road race.
Much as though I'm not convinced by his Puerta related explanations (any more than Schleck's £5,000 training plan), I'd find it hard to justify villifying the guy on the basis of his decision to go on without Schleck.
Posted 1 year ago #
Topic Closed
