Hello all,
I’m having real issues getting the rear canti brake (tektro CR720’s) on my cross check to actually work. The front Canti is fine. I’m running new pads, clean rims, smooth cables, pad contact good – with STi’s.
Little experience with canto brakes, what are my options / your experiences:
1. Do the v-brake specific drop levers, direct to mtb v-brakes work well – (as well as mtb v’s on flat bar levers?)
2. Do i need the above with short arm / mini v-brakes?
3. Can i use my sti’s direct to mini v-brakes?
4. Can i use my sti’s to mini (or regular) v-brakes with those cable pull adaptors – do they work well?
5. Is there a great working set of canti brakes out there?
6. Do i need to give in and take it to a bike shop?
Or are all cantis just rubbish?
I would like to be able to lock out the wheels and get decent braking power, ideally from the hoods.
