I bought a set of S/S wheels a while ago. Superleggra TI rear DT Swiss 350 rims Sapim CX Rays. Less than 1400 grames all in.
Mixed views for me, rear was incorrectly built, one spoke had been inserted from the wrong side causing a horrible spoke path. Fixed that myself easily enough. Spoke tension was very low on both wheels but again easily fixed.
Rear Bearings developed play within about six months, S/S couldn’t tell me the sizes I required but did send me a good A4 instructional. New bearings were easy to fit and cheap.
I like the ‘buzz’ from the freewheel but if it gets on your nerves a small amount of grease makes it almost silent.
So, All in all If you don’t mind a bit of fettling then they are good value. If you want to fit and forget stay away.
