superstar rotors - ...
[Closed] superstar rotors - seen this problem?
[#3725031]
Anybody else damaged pads from them? I can't see/feel any burrs on the rotor, but it also seems doubtful that a bit of grit would stay in the pads long enough to wear a 1 mm deep hole into a sintered pad.
The left pad also has similar marks but they are very light. They haven't been rubbing, and have only done about 85 km so far.
Maybe it's a conspiracy to make me buy more pads? 😆
Posted : 29/02/2012 10:34 am
Not had any issues with my Superstar Rotors, sorry...
Posted : 29/02/2012 10:36 am
poorly fitted, I'm afraid
Posted : 29/02/2012 10:40 am
scaredypants - Member
What? It took me ages to find a rock which fitted those stupid little rotor bolts 🙁
Posted : 29/02/2012 10:49 am
Is there potential for the rotor to have a slightly raised edge on one of the machined gaps in the disc? I would take the rotor off, inspect, lay on a flat surface and then go over the breaking surface with a sanding block. Once you are satisfied that there are no burrs, raised edges or anything else that might gouge a pad, refit.
Posted : 29/02/2012 10:52 am
At a guess one of the holes in the rotor's braking surface has a burr which isn't wearing away very quickly, but it is taking the pad surface off.
Check your rotor ASAP for any raised edges.
Posted : 29/02/2012 10:58 am
Its a poorly fitted caliper. not rotor. LOL how to you fit a rotor wrong........... my god spellingz
Posted : 29/02/2012 11:01 am
Janesy - Member
I don't know - equally though, how could you fit a caliper incorrectly and cause this?
bigyinn - Member
blahblahblah - Member
Cheers for the sanity check, I'll have another look - couldn't see any last nigjht tho.
Posted : 29/02/2012 11:30 am
I'd say the incorrectly fitted caliper is BS. You would end up with uneven pad wear, not grooves in them.
Posted : 01/03/2012 10:24 pm
I concur
Just out of interest retro83, were they noisy? I have SS sintered pads that make a racket.
Posted : 01/03/2012 10:29 pm
Ive had this before, it was because the caliper was'nt aligned with the rotor correctly. The caliper was 'raised' away from the rotor so the top of the rotor was rubbing the pads. The top of the rotor should be above the pads - ever so slightly.
I had it with Avid Elixers with 'spacers'(like old V brake spacers) on the rear post mount. caliper was too high.
Again - not making much sense as ive had a HARD day. Pretty knakered.
Posted : 01/03/2012 10:39 pm
Mine were howling a bit last night, so they do make a bit of noise sometimes.
Posted : 01/03/2012 10:44 pm
Haven't had a chance to look at the rotor yet. Will post a pic if I find the cause!
tenfoot - Member
I concur
Not at all, only time I've had that on sintered pads was after I used muc-off disk cleaner. Oh and once when they got really cold up on snowdon. Quite handy alerting walkers to your presence 😀
Janesy - Member
Think i know the setup you mean. These are Shimano/Post mount, so other than alignment (which is bang on afaict) can't see anything you could do wrong...Besides, it's only on the right hand pad, and it's a (number of) groove(s) in the middle of the pad!
Posted : 01/03/2012 11:01 pm
i`m with janesy 🙂
Posted : 02/03/2012 12:09 am
Weird one tbh... That's a big ol' score, it should be very obvious to the touch what's causing it, if it's still there. Makes me wonder if you're looking at something that happened fast, rather than a persistant scraping, but it doesn't look that way. Examine rotor more closely.
Janesy - Member
You would see the same wear on both pads if that were the cause.
Posted : 02/03/2012 12:13 am
Assuming hte isc is ok, the only possible cause for that sort of wear pattern would be getting a bit of grit or something stuck in 1 side of the rotor vent hole and gouging out the friction material.
Perhaps there was a burr which wore part of the friction material down but has since gone. It would take a while for the rest of the pad to wear down to the bottom of the groove. So perhaps the groove is historical and not recent?
Posted : 02/03/2012 11:08 am
