Strange wheel align...
[Closed] Strange wheel alignment in forks problem
[#2089842]
I have a 2005 specialized rockhopper.
When i first got the bike recently i noticed that if you drop the front wheel in and tighten it as normal then it sits on an angle and you have to mess about to get it straight, i thought nothing of it and that it was a fork issue.
I have now fitted some new Rockshox sid race forks and the issue is still there so i thought it may be the wheel but i have tried a wheel from my other bike and that sits on an angle too.
I am now wandering if it is tricking my eye slightly and it is actually the forks sat in the frame slightly off, headset or frame problem maybe?
Has anyone seen a problem like this before? is it common? what on earth should i try next or should i just live with it?
Once i have the wheel centered the nit causes no problems, the bike steers and rides perfectly.
Posted : 15/10/2010 9:57 am
It's a known problem with SID forks from a year or two back too. Should have been sorted by now though.
Posted : 15/10/2010 9:59 am
They are 2009 forks but unused, it is strange that my manitou forks had the same issue though or is it more common than i think?
Posted : 15/10/2010 10:02 am
If its the same in both forks, then it's unlikely it's the forks.
Your wheel probably needs re-dishing.
Posted : 15/10/2010 10:04 am
Straight in which way? As in the wheel is not in the middle of the fork arch, or it leans towards the right at the fork/to the left at the ground?
How are you aligning the wheel? If it's not completely in the dropouts it may result in an accute case of DEATH!
Is the wheel dished properly?
Posted : 15/10/2010 10:10 am
The wheel leans, as you sit on the bike it is to the left at the top and right at the bottom, you have to then lean the wheel back over approximately 8-10mm to get it straight.
I have tried another wheel and that sits the same.
Posted : 15/10/2010 10:11 am
That would suggest the forks then, be a coincidence it both sets were like it though.
Posted : 15/10/2010 10:13 am
i`ve noticed that qr forks i've owned with a spring only in one leg tend to do this.
my 20mm axled manitous didnt as much but i guess they are alot stiffer than qr manitous/psylos and toras.
10mm seems alot though! forks bent? flip the wheel over so disk is on other side to see if dishing is a problem.
Posted : 15/10/2010 10:21 am
I have just checked and it is more like 4-5mm, sorry about that, my guesstimate was way out!!
I have flipped the wheel and it is the same.
What about filing a little metal out of where the axle sits on the forks to true it back up?
Posted : 15/10/2010 10:44 am
Possibly a stupid question, but you haven't fitted one of the conical QR springs the wrong way around? Should be small end pressing on the axle, large end seated in the reccess of the skewer ends.Get one backwards and the spring goes over the axle, prevents it sitting correctly and your wheel becomes misaligned.
Posted : 15/10/2010 7:03 pm
