Stems for Carbon Ba...
[Closed] Stems for Carbon Bars
[#3318876]
I heard that Carbon Bars need to avoid "point loading" and so certain stems are preferable to others - I'm thinking of using a 50mm Thompson X4 stem with my easton Monkeylite dh carbon bars, but the contant point inside the clamp with the bar is not continuos - anything to wory about?
Alternative suggestions? Ive got a Renthal Strata Duo but if anything that looks like it has more point loading.
Posted : 05/11/2011 10:07 am
I've used those DH monkeylite bars with a load of different stems and never had any issues. Never really thought about it tbh.
I suspect the advice you refer to might be for thinner XC bars?
Posted : 05/11/2011 10:21 am
Been using various combinations of X4 stems with Carbon bars for about six years, never an issue.
Posted : 05/11/2011 10:28 am
The easton haven stem is a great stem and has a good system where you tighten top bolts first on the clamp then torque bottom bolts so to even pressure out. Looks nicer than Thomson aswell imo.
Posted : 05/11/2011 10:34 am
 br
Recommend using a Ritchey Torque Key.
I use those bars with both Hope and Easton EA90 stems, not had a problem.
Posted : 05/11/2011 10:37 am
Looks a bit chintzy and flash compared to Thomson, IMO.
Posted : 05/11/2011 10:38 am
Various Thomsons on various carbon bars here & never a problem. Always torqued to bolts to 6Nm. I use the Superstar preset torque thing, but only after checking it at work first.
Posted : 05/11/2011 10:39 am
