Do you have to have UST rims for ‘Ghetto’ tubeless?
Also , sorry for the remspac question , Do you also have to use UST tyres?
No – standard rims and standard tyres (but not all) I use Racing Ralphs on DT swiss 4.2 rims. 20 inch Schwalbe innner tube (presta with removable core) and 60 ml of latex does the rest.
I’ve run them for over 3 months and finally came to grief when I hit glass and sliced through the tyre – too big a hole for the latex to fix. I was doing an event and in haste whipped out the schwalbe tube and inserted a normal tube. BUT…
the replacement tube went flat withing a mile – I had assumed that it had prolapsed through the tyre and finally worn through. It was only when I got home to fix the tyre and re ghetto it that I discovered 6 thorns poking through!! These had been in the tyre for some time and I just didn’t think of checking when I had the flat – after all I’d hit glass…
Ghetto is about £12 for 2 tyres – so a lot cheaper as well
