Stan's crest d...
[Closed] Stan's crest ding 🙁
[#4017195]
After advice - managed to bend one sidewall of crest rim after all of 70 miles - just hit a square edge rock not seen at high speed.
It's leaking air v slowly (tubeless) but almost true. Do I a) try straighten myself b) get someone else to do a or c) new rim and rebuild? (hope hoop on new pro 2 hub)
James
Posted : 29/05/2012 9:12 am
May as well try a) or b) before c). If you're a ham fisted oaf get someone else to do it. Otherwise do it yourself.
Posted : 29/05/2012 9:13 am
They bend back fairly easily, I used an adjustable spanner with a soft cloth in the jaws to prevent scratches after I dinged both a crest and a 355. No problems with the rims since.
Posted : 29/05/2012 9:26 am
If the bend is over a large section of the rim it should be possible to bend it back, I used the channel that a roller shutter door runs in to recover a Crest which had 20+mm of deflection over about 150mm. It is still holding air with a yellow tape Stans setup.
Posted : 29/05/2012 10:00 am
Use an adjustable spanner and piece of leather to protect the rim,and very gently straighten it
Posted : 29/05/2012 10:26 am
Nice one cheers guys. Will fiddle tonight and resurrect the wheel...
Posted : 29/05/2012 11:38 am
