SRAM XX1 - stupidly...
[Closed] SRAM XX1 - stupidly small gear ratio?
[#4796863]
Hi,
I just saw a video presenting their new XX1 1x11 system. The biggest cog on the cassette is...42! I might miss something I guess because to me, a 42 tooth cog coupled with the rather small chainring of the system might require to spin hell fast in order not to fall from the bike, right? Why such a small gear ratio??
Posted : 25/01/2013 7:45 pm
I think it's for hills 😉
The lowest combination of 28x42 is still higher ratio than your typical 22x42 granny ring on a triple (and most will go for a bigger chainring anyway).
Posted : 25/01/2013 8:03 pm
32x42 is a ratio which is close enough to 22x36 for what they wanted to achieve...
But you don't lose too much at the bottom end. Big gaps between each gear though.
Posted : 25/01/2013 8:04 pm
i went for 28T front as i live in mountain territory.
Posted : 25/01/2013 8:11 pm
The_lecht where did you get your 28t? Local or online? Been searching for stick!
Posted : 25/01/2013 8:19 pm
Just to state the obvious... But a 32 front, 42 rear is more or less the same as a 22 front, 28 rear- so not outrageously low at all. You can fit a bigger ring of course and push the ratios up.
You are right the gear ratios are comparable to a more "standard setup".
It just looks a bit wrong to me though as I always find pedaling more efficient for a given gear ratio when I'm on a bigger chainring...Maybe this is just psychological however.
Posted : 25/01/2013 8:20 pm
 mboy
The 28T (smallest they do) combined with the 42t rear cog gives exactly the same low 0.66:1 ratio that a 24T granny on a 36T cog gives (common on most 10spd setups now), so it's hardly any more ridiculous than anything else out there currently.
That said, lowest gear I ever use, even on really long/steep climbs, is 24/32, or 0.75:1, so if I went for an XX1 setup, I'd go for a 32 or probably a 34T ring to maintain enough top end speed whilst still having a usefully low enough bottom gear.
Posted : 25/01/2013 8:26 pm
No, it's almost as if someone thought it through. 🙂
Posted : 25/01/2013 8:32 pm
A 42 rear sprocket just seemed really too big to me at first but I admit I should have had calculated the ratios before posting 😕 .
However I think it might feel quite different to a 2x10 or 3x9 setup. I would also be worried by chain crossing with a 1x11.
Posted : 25/01/2013 8:35 pm
Weird how suddenly its all gone bigger rings and sprockets and lower chain tension
I can remember when 22T and micro drive were the new thing....
Posted : 25/01/2013 8:36 pm
Groundskeeperwilly. Have you tried Dipper at Gravity Sport in Buckie? Fire him an email from his website as he might be able to help.
Posted : 25/01/2013 8:44 pm
thanks messiah-will do that now.
Posted : 25/01/2013 10:50 pm
I'm interested so many people are going for really small rings with XX1, I'd go for 36 at least, possibly 38t!
Posted : 25/01/2013 10:55 pm
That's because they're better at spinning than you! 😛
Better wear and higher efficiency.
Posted : 25/01/2013 11:01 pm
njee20 - Member
I think for a lot of folks the attaction is a 1x setup that doesn't give away the low gears- people who didn't do 1x10 are all over XX1, and they'll tend to want small.
Posted : 26/01/2013 12:50 am
Yes it has the range but the jump between ratios is horrid, no thanks.
Posted : 26/01/2013 1:41 am
barkit - Member
...I always find pedaling more efficient for a given gear ratio when I'm on a bigger chainring...Maybe this is just psychological however.
Can any one shed light on if there is anything in this or not because I have thought the same?
Posted : 26/01/2013 2:12 am
It's to do with the angle of the chain - more acute angles are less efficient, more frictional losses.
Quite possible, but a 28-10 is still a pretty damn low gear. I run 1x10 with a 36, and I'd go go a 38 before a 34, although admittedly the place I'd have use for that would usually be on the road to the trails. Suspect Northwind is closer.
Surely it's virtually identical jumps to a 10 speed 11-36 or 9 speed 11-32? 😕
Posted : 26/01/2013 9:38 am
[quote=[url= http://singletrackworld.com/forum/topic/sram-xx1-stupidly-small-gear-ratio#post-4617490 ]njee20[/url]]Surely it's virtually identical jumps to a 10 speed 11-36 or 9 speed 11-32? 😕
Don't let your [b]informed opinion and logic[/b] get in the way! Actually, it's identical to 9-speed 12-36 block, with a granny gear (assuming 32t "middle" ring)... using the 11-speed XX1 cassette (10-12-14-16-18-21-24-28-32-36-42), that's the same as 27t/32t... with a turbo gear of 38t/12t or 35t/11t. Not quite a triple, though XX1 is more a 1x alternative to those on 2x drivetrains and rocking something like 26t/39t with a 12t-36t 10-speed cassette. :mrgreen:
Posted : 26/01/2013 1:01 pm
Oh I think its a brilliant idea. Its just intresting that the same industry that took it away are now brining it back as a good idea
Posted : 26/01/2013 1:39 pm
