2014 Zesty, finished a run this morning, started pedaling the bike back up and noticed a squeak has started to emit when the suspension is compressed. Fairly sure it’s coming from the linkages around the shock area / swing link. Pretty sure not shock bushings as replaced shock and fitted new bushings not so long ago.
Aside from a full bearing replacement (for which I can source bearings, but not confident doing as don’t have the tools, so will be a costly lbs job), is there anything else i should be doing to see if I can avoid replacement, or should I just bite the bullet? If so how much should I be looking to pay for a bearing replacement (10 bearings I think)?
