Splitting SRAM chai...
[Closed] Splitting SRAM chains ...... tips?
 Moe
[#2980410]
Having injured the tendons in my hand and a resulting slow recovery this little job is now even more problematic than normal, surely there's a gap here for someone to engineer a tool for the job?
Posted : 25/07/2011 4:09 pm
Old gear / brake cable wrapped around a couple of links, couple of cloths to save the fingers, a quick pull and 9 times out of 10 pain free.
The tenth one gets cut in half with the cable cutters.
Posted : 25/07/2011 4:11 pm
Squeeze gently, push pins together
GT85 helps
Oh, & there is a tool
Posted : 25/07/2011 4:15 pm
 Moe
Cheers, I'll give that a go.
Found this thread but no real advice on the elusive 'knack'!
[url=http://] http://www.singletrackworld.com/forum/topic/splitting-sram-chains-and-powerlinks-enlighten-me-further-peeps [/url]
Posted : 25/07/2011 4:16 pm
There's a wee pliers you can get....
http://www.chainreactioncycles.com/Models.aspx?ModelID=46600
Posted : 25/07/2011 4:17 pm
Try to pinch the plates together with your left hand - thumb and index [if you're RH]
that's finger ends squeezing, just the plates
With your RH push the adjacent link towards the one you're pinching
Posted : 25/07/2011 4:20 pm
I find it helps to think about taking it off when you decide which way around to fit it. (no use now unless you have a time machine)but I find it easier to push away with the right thumb and pull towards with the left before sliding them towards each other.
Posted : 25/07/2011 4:50 pm
Posted : 25/07/2011 4:57 pm
Before i got the specific tool, i just used a pair of groove lock pliers and press alternate corners of the powerlink, worked 100% of the time
Posted : 29/07/2011 1:32 am
What I find helps is not using such a rubbish product in the first place.
Try Connex powerlinks. Stupidly easy to get undone with just your fingers. Even with gloves on.
Posted : 29/07/2011 1:45 am
We've got the KMC one recommended above (just sold by Fat Spanner,and probably cheaper)in the workshop, well worth having.
Posted : 29/07/2011 7:10 am
