So, just looking for some reassurance that I have the below correct…
My network is made up of a variety of components, and I’ve put what I believe to be their speeds below. I’m assuming that these numbers indicate that when everybody’s home and connected and iPlayer is slow on the TV and a game on the PC is laggy or an iPad is slow at opening web pages it’s because of my broadband speed?
laptop = wifi g = 54 Mbps
iPad = wifi n = 150 Mbps
broadband (mine, at least) = 5405 Kbps down / 448 Kbps up = 5.4 Mbps / 0.448 Mbps
router = gigabit = 1024 Mbps
network card = gigabit = 1024 Mbps
homeplugs (TV and lodger’s computer) = max 200Mbps
“What’s that darling? Eastenders is breaking up and blocky on the TV? I knew something was up with the broadband, TeamFortress 2 is almost* unplayable at the moment as well – have to hope it resolves itself in time for us to watch that movie later…”
*perhaps largely because I’m not a 14 year old American.
iPlates make no difference if your internal wiring is ok. All it does is disconnect the bell wire from the internal wiring.
You only need lines 2 & 5 connecting up on any internal wiring. (wire 2 is Blue / White stripes, wire 5 is White / Blue stripes), anything else can usually be disconnected.
If I were to be picky the wifi speed you’re getting will be limited by the speed of the wifi routers wifi. Doesn’t matter if the iPad can do 150Mbps if your router can only do 54Mbps – the ipad will do 54Mbps (or less in practice). IIRC the speed of 802.11n (what the iPad has) is dependant on the number of attenias the thing has as it’s a MIMO implementation.
Thanks for the iplate recommendation / thoughts… having read those links I’m going for one because I *think* our broadband isn’t able to be plugged into the main socket (due to the crumbling bodges of the idiot ‘improver’ who had it before us). And I’m not tech / confident enough to want to play with wires myself!
Router is a BiPAC 7800n which does wifi n to 300 Mbps (if supported, natch) and has three antennas.
EDIT: Argh! Our BT phone plate has two plugs in it – one a BT line with the broadband and a fax and one a T-Mobile line with the phone. Grr!
This isn’t speed, it’s latency. Go to a command prompt and ping a local server, eg ‘ping http://www.bbc.co.uk’ note the response time in ms and post it here.
Don’t get an iPlate, they’re pointless. Get one of these instead.
Pinging http://www.bbc.net.uk [212.58.246.93] with 32 bytes of data:
Reply from 212.58.246.93: bytes=32 time=30ms TTL=57
Ping statistics for 212.58.246.93:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 30ms, Maximum = 30ms, Average = 30ms
Currently with one computer doing nothing much, one computer doing stuff, one xBox doing something and an internet radio playing merrily.
Sorry, was wrong about two separate lines (though I know we have two, FWLIW), but it is a double socket. Like this (you can just make out the second socket rhough the glare!):
If anybody is following any middle class thread, I had to move a Le Creuset box out of the way to take the photo :p
Two things. That’s not a master socket, it’s an extension; all other things being equal, you’d fit the plate on the master. You’d (probably) fare better by relocating the router next to the master socket and then just pushing the phone side of the line to the fax etc.
Latency is good; you’re not going to get much better than that, so your issue is Something Else.
I’m utterly confused about this double socket thing. What’s the crack, is that just a splitter? Ie, are both sides ostensibly the same?
Hmm. Have no further idea on the wall socket. Will open it up and have a look (and take a photo). And ask my wife what she thinks each side does, as she spoke to the BT chap!
The router is a Billion 7800n. I’ve always thought it to be great, but am v open to being told otherwise. Reference torrenting, I’ve asked before – a year or two ago – and he said no. I’ll ask again – and maybe start checking broadband usage!
It’s on the TV that it’s really noticable, unwatchable really.
Posted 12 years ago
Viewing 16 posts - 1 through 16 (of 16 total)
The topic ‘speed / unit help please: broadband, switch, network card and wifi speeds…’ is closed to new replies.
