Specialized Tricros...
[Closed] Specialized Tricross Sport 2010
[#1359293]
Has the brake judder issue been solved? can you still fit mud guards as the brake holder thingy seems to go through the guard fixing hole.
Anyone got a 2010? good or bad.
For light touring, commuting, bivvy biking etc.
Cheers y'all
Plum
Posted : 24/02/2010 10:56 pm
I don't own one, but the shop where I work has sold several
brake judder seems to be much sorted
'10 brake mount makes it a PITA to fit a mudguard, but it is possible. You just have to monkey around with the brackets
Posted : 24/02/2010 11:00 pm
I have a 2009 with new bracket fitted,the original bracket was just below the handlebars,the new bracket is fitted just above top of the forks.Also mudguards fitted no problem
all bike shops have cured this problem with the new bracket,if not then force them to rectify it,but I think you would find it hard not to find a tricross with the work not done.The tires are crap if doing canal paths picks up punctures easy.Hope this has helped.
Posted : 24/02/2010 11:21 pm
 ton
Thank you all - thats a new bike sorted then.
I was gonna ask for cross tyres to be put on too
Ta
Plum
Posted : 24/02/2010 11:28 pm
I'd argue with the tyre comment - I use Boroughs on my hybrid (not a Tricross, but same tyre), which spends a lot of time on the Exeter ship canal towpath and they are fine until worn out (they do get paper thin on the tread and get puncture-y but that takes some mileage - bearing in mind that I work on my bike as a cycle instructor and do a lorra lorra miles)
Posted : 24/02/2010 11:30 pm
I've found the Borough CX tyres on my '08 brilliant on the road, found chunks of glass in them without punctures.
Rubbish as soon as you hit anything that looks remotely like mud though.
Posted : 24/02/2010 11:33 pm
now that, ctznsmith, I'd go along with
Posted : 24/02/2010 11:40 pm
