Slimy patio - does ...
[Closed] Slimy patio - does it need a power washer?
[#3546251]
Suspect it hasn't been cleaned for donkey's years and it's actually quite slippery. Would I be better off buying a power washer or would a stiff brush be able to cope?
As always, thank you so much. 🙂
Posted : 09/01/2012 9:03 pm
Bleach.
Posted : 09/01/2012 9:04 pm
Elf - it's ingrained.
Posted : 09/01/2012 9:05 pm
bleach and a broom
Posted : 09/01/2012 9:06 pm
Jeyes fluid and a stiff brush. And some elbow grease. 😉
Posted : 09/01/2012 9:08 pm
Good old [url= http://www.jeyes.com/en-gb/our-products/jeyes-fluid/ ]Jeyes fluid[/url]
EDIT: beat me to it
Jeyes fluid and a brush
Pressure washer would work but it can be rough on the slabs and doesn't prevent re-growth.
Posted : 09/01/2012 9:09 pm
I use industrial bleach, mix it half and half with water and put it on with a garden pump sprayer. Give it a scrub with stiff sweeping brush then rinse after 30 mins if you want to walk on it. Better and quicker than power wash which breaks up the pointing.
Posted : 09/01/2012 9:11 pm
Elbow grease? With a shoulder separation? Oh well, I do have one good side so shall get busy with the Jeyes.
Thanks for the replies. 🙂
I put salt/grit down during the last big freeze. Once the thaw came I brushed the reminants off the patio. Surprised to see how clean it had made it, killing off all the green stuff.
Posted : 09/01/2012 9:15 pm
Sharp sand works well, sprinkle some across the offending area, then use the stiff brush to sweep it up.Think of it as a bit like rubbing your Patio down with sandpaper 🙂
Posted : 09/01/2012 9:20 pm
Sharp sand the dry sort thats used in childrends sand pits, sprinkle thinly then with a watering can full of strong bleach, soak well leave overnight.The sand keeps the bleach in place.
Keep animals inside.
Then a rough brush and plenty of water, wear wwellies as the bleach makes your jeans holey and spotted.
Posted : 09/01/2012 9:25 pm
Once removed is there anyway of preventing it coming back as this is a reoccurring event for myself too.
Posted : 09/01/2012 9:27 pm
clear sealant like thompsons water seal.
Posted : 09/01/2012 9:32 pm
I use a jet wash, messy and tedious but gets it spotless - although the mold / moss just grows back slowly....
Posted : 09/01/2012 9:35 pm
Power washer with one of those patio-specific attachments. They really do work well.
They stop you getting soaked and it allows you to get your patio cleaned up a lot quicker.
Posted : 09/01/2012 9:38 pm
Power washer and brush is the right tool. Bought one specially to cleanup ours before selling. Worked a treat.
Posted : 09/01/2012 10:16 pm
This Nilfisk jobby will sort you out:
[url= http://www.amazon.co.uk/gp/offer-listing/B001TUYV1O/ref=dp_olp_new?ie=UTF8&qid=1326144420&sr=8-2&condition=new ]Nilfisk[/url]
only £56.99 at the moment from Amazon as well 🙂
Posted : 09/01/2012 10:29 pm
I'm in the same boat as C_G too (hope you don't mind the mini hijack).
I have the pressure washer with the patio attachment (which makes the world of difference to the time it takes) but regrowth is an issue here too. I've got some ranom patio cleaner stuff but stupidly only read the instructions / warnings after I'd bought it...
The problem I have in using any of the bleach / cleaner fluids is the proximity of the lawn - the patio runs off to there. Anything a bit more eco friendly? Stupid question probably... I might try the sharp sand option coupled to elbow grease.
Cheers.
Posted : 09/01/2012 10:40 pm
Try using a product called "Patio Magic".
It's pretty good stuff. However, if your patio is in the shade at this time of year then whatever you use is going to struggle to stop the slime coming back.
gonetothehills - I have used Patio Magic in my back garden and my slabs butt up to the lawn and I have had no problems with it.
Posted : 09/01/2012 10:49 pm
I found that round Patio attachment was next to useless and had to use the needle jet to clean the paviers, hence a slow and tedious job as my Patio has over 2000 off them to clean!
Posted : 09/01/2012 11:03 pm
Thanks Ho hum - will have a look for it. You're spot on about the shade - it's exactly the issue. There are parts of our garden that don't see sun at all at this time of year, and that's where it's worst. Oh, and the fact we're tucked under the hills too... Still - that has its benefits in other ways 🙂
