I have a superstar -2 deg slackset in my bike ,taking the head angle from 66 to 64 deg.
Initially the new headangle resulted in a lot of ‘understeer’ (ie the front on the bike didnt want to turn, just wanted to push straight on)on flatter trails, this was because there wasnt enough weight over the front wheel, so I took out a couple of spacers from under the stem to lower the bars, and also rotated them slightly so that the grips were slight more forward, this put more weight over the front which fixed the handling issue. Now the bike is great, works really well. No problems climbing , descends brilliantly.
In an ideal world I would have lengthened the chainstays to achieve the same result rather then lower the bars, but thats not really an option.
So if you try one out and the front feels a bit light, just try lowering the bars a little to get more weight over the front.
