Shimano XT Pulley?!
[Closed] Shimano XT Pulley?!
[#1817096]
This may be a simple question, but it's only simple if you know the answer right?
I need to relapce my jockey wheels on my xt rear mech. How do you tell the difference between a tension pulley and a guide pulley? Can the jockey wheels really be that different?
Posted : 20/07/2010 1:16 pm
It says top & bottom on them. Oh & yes they are different, if my memory serves me correctly they have a diffferent number of teeth on each (though i could be mistaken).
Posted : 20/07/2010 1:26 pm
it says top and bottom on what? The derailleur or the wheels?
Posted : 20/07/2010 1:32 pm
Hmmm I may have to start a thread based on this!
Top ones float laterally IIRC.
Posted : 20/07/2010 1:35 pm
The jockey wheels will have written on them top, bottom. Which will tell you which one is the top & which is the bottom. Strangely enough...
Posted : 20/07/2010 1:41 pm
So as I need to replace top and bottom jockey wheels, I need both tension and guide variety?
Posted : 20/07/2010 2:01 pm
The "jockey pulley" is the top pulley (closest to the gears).
The bottom pulley is the "tension pulley"... takes up the slack and doesn't need the side-to-side play.
Problem solved.
Posted : 20/07/2010 2:04 pm
Get the [url= http://www.dotbike.com/productsP3992.aspx ]BBB ones from dotbike[/url] - they even have 'top' and 'bottom' written on them.
Posted : 20/07/2010 2:10 pm
Guide (top) pulley has a ceramic bushing, has side to side float to aid shifting.
Tension (bottom) pulley has a bearing, does not float side to side.
Posted : 20/07/2010 2:13 pm
As an aside, has anybody used the KCNC jockey wheels?
Posted : 20/07/2010 2:42 pm
Nope, but can heartily recommend the [url= http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=260609455917#ht_780wt_913 ]TACX[/url] ones for £9.....they even have top and bottom written one them 8)
Posted : 20/07/2010 2:44 pm
Thanks
Posted : 20/07/2010 2:54 pm
