Is having squealing/heavily vibrating hydraulic brakes (Shimano XT) a harbinger to the fact I need new pads, and are there any pads that are less likely to be noisy than others?
Bike Forum
[closed]
Shimano pads (squealy brake content)
Posted 3 years ago #
Worn out pads normally make grinding and grating noises, squealing and vibrating is usually down to contamination(such as oil on the pads), glazing(dragging brakes on long descents?), or maybe a misaligned caliper/sticky piston(do both pads hit the disc dead square and at exactly the same time?).
Also worth checking all your bolts are tight too.Posted 3 years ago # -
Cheers coatesy, I suspect it may be glazing then as everything else seems in order, is there any cure for this apart from not being a sissy and using my brakes so much on long descents?
Topic Closed
