Viewing 9 posts - 1 through 9 (of 9 total)
  • shimano ht2 cranks
  • fresherjohn
    does anyone know if the splines on the axles are the same throughout the range?
    I’ve stripped the thread out of a non-drive side XT crank and was wondering if i could replace it with a lx, or any other in the range?
    cheers
    coatesy
    not sure, but a longer bolt or having it helicoiled would probably be cheaper anyway.(assuming it’s the clamp, not pedal thread)
    Steve-Austin
    the splines are all the same, but i think the q-factors on some are different
    fresherjohn
    its the pedal thread unfortunately.
    whats a q-factor?
    shindiggy
    Quality factor i presume? Though it doesn’t make sense, lol
    cynic-al
    q factor is width of pedal thread face
    coatesy
    Just to be clear, q-factor is the distance between the outside pedal faces of the crank, measured as if one of the cranks were removed and pointed in the same direction as the other. Too wide a Q-factor and your pedalling stance will be like John Wayne.
    matthew_h
    You should be able to get your stripped pedal thread helicoiled so you don’t need to scrap you crank
    toys19
    Cyclus do a kit see here but its 140 quid from dot bike..
    I am sure a good bike shop will do this for you.
The topic ‘shimano ht2 cranks’ is closed to new replies.
