Bit confused by this – there’s no noise or skipping in any gear, shifting to a bigger sprocket is fine, but shifting to a smaller sprocket doesn’t happen with one click.
I have to shift twice then back once to get to a smaller sprocket.
Chain and rear mech are clean, and I’ve just replaced cables and housings to try and fix this BUT IT STILL HAPPENS. 😥
If I back off the cable tension then I have problems shifting to bigger sprockets.
According to a chain checker, the chain just needs replacing, but googling suggests that a worn chain will skip rather than produce shifting problems in one direction.
I guess I’ll change the chain soon anyway, but does anyone have any ideas what could be wrong? Bent rear hanger?
This is 2×10, deore shifter and shadow+ rear mech (but it still happens with the clutch on or off), SRAM cassette and KMC chain.
