Shaving oil - what ...
[Closed] Shaving oil - what the hell do you do with it?
[#3451081]
Now my normal morning routine is to have a shower, then have a shave.
If I'm cycling into work I'll just have a shave, go into work and have a shower there (And since I ride into work normally 4 times a week, this is my normal routine). Sadly this makes shaving a bit harder, I presume because my face hasn't got properly soaked or something. So shaving, even with foam, is sometimes quite painful and often leads to bloodshed and always leaves my face feeling raw.
So I tried some shaving oil which definately helps. Thing is, this leaves me in a quandry.
When I'm shaving normally after a shower and use the oil, do I wash it off with soap, or not?
The latter leaves my face feeling oily.
What are you supposed to do? (MTFU?)
Posted : 11/12/2011 10:06 pm
I use King of Shaves menthol oil when travelling. Nice hot shower, five drops rubbed in to face. Shave. Then just dry face off a little. It's excellent stuff.
Posted : 11/12/2011 10:08 pm
Have you tried a King of Shaves gel?
Jeez flashy, do you ever read OPs anymore?
Posted : 11/12/2011 10:10 pm
King Of Shaves gel is supposed to be good.
Personally, I have no idea as am a scruffy urchin.
Posted : 11/12/2011 10:11 pm
I gave up on the oil after a while, it makes a right mess of your shaver. Currently trying Clinique aloe gel/post shave balm stuff, seems good so far.
used king of shaves gel for a while, which is ok, but I think I prefer the Clinique stuff.
Posted : 11/12/2011 10:12 pm
WTF is wrong with soap?
Posted : 11/12/2011 10:15 pm
hot water, as hot as you can cope with. KOS gel, shave-with any kind of razor, rinse. moisturise with something you like the smell of. done.
I do that and have stubble within minutes. 🙂
Posted : 11/12/2011 10:16 pm
Soap really dries your skin out.
No need to wash the oil off after a shave. Just rinse with water and dry off.
Oh, and wash with some type of scrubby stuff to soften bristle first with as hot water as you can stand. You can rub some (el cheapo) moisturiser in before using a gel (other non-lathering gels are available). Rinse off with cold water. Moisturise.
Because you're worth it. 🙂
And that's as metrosexual as I'm getting tonight.
I don't know, what is wrong with soap?
I'm with you there Charlie, that's what I'd normally do if I was travelling, shaved with cold water before now because I'm dead tough like Sly in First Blood but going to work with dirty greaty bleeding holes in my face doesn't create the right impression.
Apparently.
Posted : 11/12/2011 10:17 pm
And ta, I'll try king of shaves.
Posted : 11/12/2011 10:18 pm
Have you considered growing a beard?
Posted : 11/12/2011 10:19 pm
It's because he was trying to cross the road.
I find men with beards suspicious and difficult to trust.
Plus I think a beard makes me look like a paedo.
Posted : 11/12/2011 10:20 pm
Posted : 11/12/2011 10:25 pm
Have you considered rapist glasses to complete the look?
Posted : 11/12/2011 10:28 pm
i use king of shaves oil and gel together. massage oil in first then gel. makes shaving pretty smooth. i only shave twice a week though and try and do it on a night time as it gives my delicate skin time to calm down.
Posted : 11/12/2011 10:31 pm
Can't argue with that logic.
Posted : 11/12/2011 10:33 pm
Posted : 11/12/2011 10:35 pm
[i]WTF is wrong with soap? [/i]
blimey!
I always liked Somersets shave oil. Great stuff, much better than all the others that I tried and far better than gel, soap etc. The best bet is to always use hot water and exfoliate first.
Posted : 11/12/2011 10:46 pm
KoS Kinexium. Just leave it on, rub it in and then apply your choice of manly moisturiser 🙂
Posted : 11/12/2011 10:50 pm
Posted : 11/12/2011 11:02 pm
MTFU. Cheapest gel or foam used sparingly, nastiest plastic razor eked out for weeks and deal with the blood.
That freshly lacerated look discourages people from sitting next to you on the tube.
Posted : 12/12/2011 9:11 am
Can't you shave in the evening? That's what I used to do when I commuted by bike (can't any more *sniff*). Home, shower, shave, reasonably tidy stubble-wise for the following day.
Or shave at work?
Posted : 12/12/2011 10:23 am
 Nick
Can't you just shave in the shower at work, that's what I do. Been doing it so long now I don't need a mirror any more.
Ride to work, nice hot shower, wee, tesco shaving gel and disposable razor, no razor burn, no blood, rest of body is getting washed at the same time.
If you need a mirror then just get a small one and leave it in your desk.
Posted : 12/12/2011 10:29 am
I used to use Somersets Oil, always gave me the closest shave, but as someone has said it really clogs your razor up. I have tried loads of different shaving creams and now I use The Real Shaving Co. shave cream now and it's a really nice comfortable shave. Also I have tried all the latest razors like Gilette Fusion etc etc but found they didn't last long and weren't as comfortable as the original Mach 3, so I just use Mach 3 now and the blades are cheaper!
Shall we start a thread on what the best razor/blades are?
[i]Shall we start a thread on what the best razor/blades are?
[/i]
Use one of these and any blade feels better and lasts for ages. I reckon I get a couple of months of daily shaving out of a Mach 3 🙂
http://www.mankind.co.uk/razorpit-razor-blade-sharpener/10366474.html
I can't recommend it highly enough, it is the absolute b*ll*cks
Posted : 12/12/2011 10:35 am
I use King of Shaves oil with Mach 3 on a daily basis and no problems, just rinse my face with water when I've finished.
I find their gel is better if you only need to shave less regularly.
Posted : 12/12/2011 10:36 am
I used King of Shaves oil stuff for a while, but found that the cut hairs clung to it and wouldn't come off the razor very easily so it got clogged up.
It was also felt really greasy too, unless washed off properly after shaving with some soap or face wash or shower gel.....
I find if I shave without having a shower first, it's like a laceration-fest. I assume it's because my stubble hasn't been softened a bit by hot water....?
As above, I'd try either shaving in the shower when you get to work or shaving the night before.
I use Aleppo bay and olive oil soap for washing face, body, hair and for shaving.
http://en.wikipedia.org/wiki/Aleppo_soap
Posted : 12/12/2011 10:39 am
Is it really that good???
I nearly faint at the price of razor blades, how does it work?
Posted : 12/12/2011 10:46 am
[i]Is it really that good???[/i]
It really is. Basically it cleans all the gunk off the blade that would otherwise 'dull' it, so leaving it pretty much as good as new each time you shave.
Basically you rub the blade up the thing five or six times, using a tiny bit of gell or foam as a lubricant (there's a video and a better explanation on the site I think). I've had one for about eighteen months and use it before every shave. It does rub the lube strip off the blade, but you realise that with a clean blade and decent gel (I use King of Shaves), you don't need the strip anyway.
Easily a month per blade probably two (I don't really take any notice any more, as I'm so rarely changing blades). Plus, you can store your razor in it for trips away.
I'll say it again, I cannot recommend it highly enough.
Posted : 12/12/2011 10:57 am
They have got them on Amazon for £14 so may order one, the reviews of it on there are 90% favourable with Mach 3 blades so looks like it could be a good investment with the price of razor blades so high.
Posted : 12/12/2011 11:00 am
Posted : 12/12/2011 11:35 am
