Shaving oil...........
[Closed] Shaving oil......... any good?
[#1739184]
It sounds horrible but does it work well? Going away for a week and want something small to take. Would rather have a small tube of cream but might not be able to get it in time.
Posted : 25/06/2010 10:58 am
Works sort of OK for that sort of situation, but I wouldn't use it all the time.
Posted : 25/06/2010 11:01 am
I have a teeny-weeny bottle for smallness. And also because the smell of mine appears to appeal to women. Or did, to woman. I don't claim it works all the time more than 60% of the time. 🙂
Posted : 25/06/2010 11:03 am
works great, i recommend you get a couple of uses in at home first.
i used to get away with cold water and oil on holidays.
can leave a bit of a residue on your face
Posted : 25/06/2010 11:05 am
Used to use it and liked it but found it would "gum up" my razor quite quickly (especially ones with more blades).
Posted : 25/06/2010 11:18 am
I had great experience of Body Shop stuff, they stopped making it then I tried KoS which blocked up my razor, so I went to cream.
Posted : 25/06/2010 11:19 am
I don't like it because of this. It's really hard to clear the razor as the cut hairs cling to the baldes due to the oil.
Posted : 25/06/2010 11:21 am
Works, and is good for two reasons - the bottle is tiny, and you don't end up having to wash loads of foam off and risk leaving a bit behind your ear 🙂
Just use olive oil
Posted : 25/06/2010 11:22 am
Just use olive oil
I refer the honourable gentleman to the second point in my earlier post, and enquire whether in his experience this works all the time even 10% of the time. 🙂
Posted : 25/06/2010 11:25 am
Hmmmm, although it probably does work I'm still not convinced. Ordered a small tube of Trumpers Coconut Oil cream instead, not cheap so I'm hoping it's great 🙂
Mediterranean women like it 🙂
Posted : 25/06/2010 11:27 am
I've been using Olive Oil (extra virgin, natch) for about 4 years. Works an absolute treat, doesn't gum up the blades - although I only get about 5 or maybe 6 shaves from a Mach 3 unlike the 20 or so that someone was saying on here the other day. Far superior to creams/gels/soap imo.
Posted : 25/06/2010 11:29 am
i found it to be useless.
Posted : 25/06/2010 11:33 am
Trumpers cream is fantastc stuff. I am using the rose one at the moment. Mrs Oddjob likes the smell and I like that it is bright pink 🙂
Posted : 25/06/2010 11:35 am
I found it made the rubber and the moisturising strip on my razor rot really quickly.
Posted : 25/06/2010 11:37 am
 -m-
2 comments:
1) It gums up your razor (although you probably got the message on that one 🙂 )
2) If you're travelling with it then when it leaks (and it will...) it gets everywhere and gums up everything - gels/creams are less prone to leaking in the first place and easier to wash out of the things they contaminate.
Posted : 25/06/2010 11:53 am
 teef
it's rubbish - you can't see where you've shaved already and where is left to do
Posted : 25/06/2010 12:10 pm
It's shit, I hate it.
Posted : 25/06/2010 2:07 pm
