This may be a bit of a longshot, but let me explain.. I have a QR Sektor (reasonably light)and I have a brother with a redundant Pike with a 20mm maxle + steel steerer (weighs a ton).
I’d like to go 20mm but i don’t want the big weight increase from the steel steerer on his Pike. So.. is there a way I could i mash together the Pike lowers and Sektor uppers? They’re both 140mm uturns but a bit of research suggests the pike lowers are 10mm longer
Scouring the web i came across this thread where someone tried the reverse (pike uppers, sektor lowers) and wasn’t successful. http://singletrackworld.com/forum/topic/sektor-lowers-on-pike-uppers-possible
Will the extra 10mm on the lowers mean i’ll smash into the seals when I bottom out? Can i add a spacer on the spring to increase the length?
