sillyoldman – Member
@nobeer – apologies, I understood it to mean air mixed with oil – what does it mean?
It can refer to a certain type of fatigue to metal parts, but also refers to gas being drawn out of a fluid. An example: if you crack your knuckles, the noise is gas being drawn from your synovial fluid as you expand the joints. It gives you a 15 – 20% increase in mobility (hence why some pianists do it), which slowly reverts as the gas is reabsorbed. That reabsorption time is why you can’t immediately crack your knuckles again.
If a dropper was based around a fluid that could do that, then the gas would probably get reabsorbed and the sag would disappear… and maybe reappear. Sag in Levs and Reverbs is due to air getting past a seal, not emerging from what’s already behind it.
