Sachets of lube...?
[Closed] Sachets of lube...?
 Bez
[#2860064]
Back in the day (mid 90s) Finish Line sold lube in little sachets (imagine the image below, but containing something you don't want on a plate of bubble). You could chuck 'em in a saddlebag and know that if your chain ever started getting a bit noisy you could sort it out.
Can't seem to find them anymore. Does anyone still make anything similar?
Posted : 17/06/2011 1:35 am
you know the little fish-bottles of soy sauce you get with supermarket sushi?
I fill those up with lube for just such an occurrence.
APF
Posted : 17/06/2011 1:38 am
Or emptied shaving oil or eye drop bottle.
Posted : 17/06/2011 6:37 am
Shimano seem to give them away at events like mayhem and SITS
Posted : 17/06/2011 7:03 am
A tube of that Fox lube would help you out of a spot I guess but as hh up there suggested, I have small dropper bottle I carry on big days
Posted : 17/06/2011 7:56 am
 D0NK
Squirt lube do a tester bottle just the right size for keeping in your pack (bit bigger thana sachet tho) And it is rather good for your chain.
Posted : 17/06/2011 11:58 am
white lightning do tiny bottles of lube which a perfect for this.
bout 1.99 in the LBS
Posted : 17/06/2011 12:01 pm
I have pink teflon grease in syringes for getting into headsets etc neatly. Quite often bung one into saddle bag if I'm away for a weekend
Posted : 17/06/2011 12:04 pm
An oily, empty lube sachet sounds like the kind of thing that would "accidentally" get left behind after a stop. Bit tricky to know what to do with, unless you carry a little sandwich bag as well for the empties.
Much better to have a little bottle with a little lid, I reckon.
Posted : 17/06/2011 12:45 pm
The smallest size Finish-Line bottle works for me, just keep it 25% full if you're worried about the weight... 😉
Posted : 17/06/2011 12:47 pm
 nuke
[i]Squirt lube do a tester bottle just the right size for keeping in your pack (bit bigger thana sachet tho) [/i]
Exactly what I use...perfect for the job
Posted : 17/06/2011 12:53 pm
